Starter issue???
Old Aug 9, 2015 | 07:57 PM
Rickk Lauderdale Smith's Avatar
Stage I
Default Starter issue???
94, 883, xlh
Having problems starting the bike. 1) Turn ignition on 2) lights all come on 3) Nothing happens when I try to start the bike. (no click or anything)
Have brand new battery and starter relay switch. What else should I look at before replacing starter? Is there a work around to get the starter to engage?
Don't exactly have enough cash for a new starter right now so any help would be greatly appreciated. So thanks in advance to any suggestions.
Old Mar 16, 2016 | 09:10 PM
Drair's Avatar
Drair
I've had starter problems of one sort or another over the years and *Sometimes* it helps to tap on the starter with a ball pean hammer, then try the starter again. If that works, I've been told it could be a solenoid on the starter itself, or a "low spot" on the starter winding, whatever that means. None of this might pertain, but if you're totally out of ideas...
Old Mar 16, 2016 | 09:38 PM
SIDECAR BOB's Avatar
SIDECAR BOB
you can also check to see if the small wire that plugs into the solenoid is getting 12 volts when ignition on and start button depressed. also check the ooops/simple things, run switch on, all grounds and cables clean and tight.
Old Jul 20, 2020 | 06:45 PM
Daveboone's Avatar
Daveboone
3rd Gear
I did check the small stud on the solenoid: run switch on, no current when starter button pressed. Audible click from the breaker switch though. (single click, not a clickclickclick ).
boy I sound like a moron....
Old Jul 27, 2020 | 08:20 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Start a new thread (in the electrical section of the forum), give info about bike (year, model, modifications) and what exactly the issue is....
Old Jul 27, 2020 | 03:52 PM
Daveboone's Avatar
Daveboone
3rd Gear
whooops....posted in the wrong thread above! I have another elsewhere. thanks and sorry!
Donn 86 flhtc
Mar 4, 2015 07:42 PM
fire48
Aug 13, 2012 11:55 AM
tom301
Mar 10, 2012 07:37 PM
glide1996
May 28, 2007 01:39 AM
zacjac
May 5, 2007 10:50 AM
