Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I asked this in another thread but figured I should start one.
I made a dumb mistake and lugged the engine with about 10 miles on it during break in.
What happened was I was at a parking lot and stopped already and tried to shift to neutral and must have shifted to 3rd, I stepped on the shifter and thought I was in first when I took off again. it started moving but I knew I must have been in a higher gear and had to start shift down.
It's been bothering me and I hope I did not do any damage. Other than that mess up i've followed the break in guide lines. Is it possible I did any damage this early?
