04 Roadking engine rebuild
Old Jan 23, 2016 | 08:11 PM
  #31
AngryWrenchMotorsports's Avatar
Originally Posted by djl
I figured as much on the cam plate, pump, etc. I was not aware of a Stage II BB kit for 95" upgrade that included the heads. Anyway, IIRC, the Stage II BB kit includes the SE203 cams which would like a little more than stock compression to optimize performance. Unless you have the early SE Performance cylinder heads (I doubt it) the chambers should be about 85-86cc. Use a .030" Cometic MLS head gasket and have the heads decked about .025". That will set static CR at about 9.65; a good but conservative number. If the heads are off, might as well take advantage and get the most for the dollar spent.
The pan part number is 62489-99a; about $150 from an online discount dealer. The piston oiler are less than $20 each; PN 22315-06A. Good luck!
By the way, I was totally wrong about the heads. I would have sworn that he said the kit came with heads, but looking through the boxes, it did not.
Old Jan 24, 2016 | 12:28 PM
  #32
mattVA's Avatar
mattVA
Originally Posted by AngryWrenchMotorsports
Finally getting back to this engine. I was installing the cam support plate and found something that looked odd. The shop manual has a picture saying I need to change out the filter screen at the top O-ringed hole shown in the picture at the arrow. The engine I am working on has no screen, in fact it looks to be a blind hole. Wondering if this is going to cause me a problem with the hybrid cam plate I am installing. Figure I will try to follow the hydraulic circuit, but would love any experience here. Also included a shot with the hybrid cam support plate installed, just because it looks so pretty.
Someone will correct me if I'm wrong but I believe that hole is only used by Softail models. I don't have any screen on my Dyna which is similar to your friends Touring bike in how the oil is delivered to/from the tank. By the way great job so far. I just split my cases and replaced bearings and seals. To get that crank seal out I had a hard time not having a slide hammer to pull on the screws. I used a bearing race puller instead, worked like a charm.
Old Jan 24, 2016 | 08:07 PM
  #33
Awesome. Thank you for the info. I didn't figure this could be an issue considering he had 40,000 miles on this engine case, but wanted to make sure. If it was a problem, now is the time to address it.
Old Apr 22, 2016 | 02:18 PM
  #34
Been so busy I haven't had time to post the progress on this.
Old Apr 22, 2016 | 02:24 PM
  #35
He has the chip flashed as of today. Bike is running smooth with just a bit more power and lope.
gdishman
Sep 30, 2018 07:31 PM
death trap
Exhaust System Topics
Feb 22, 2013 08:59 AM
lt1tyrell
Sep 16, 2011 07:17 PM
inthechateau
36
Jun 11, 2011 08:13 PM
N-gin
Sep 11, 2010 07:36 PM
