Died with a clank
Old Sep 26, 2015 | 09:08 PM
Don Francke's Avatar
Don Francke
2nd Gear
Originally Posted by Don Francke
Thanks, I will check these things tomorrow after work.
Ok I removed the spark plugs and one has a chip on it. I pushed the bike back wards in gear it did go back a foot or so then stopped pushed forward a again moved forward then stopped. Tried to use the starter it engaged once then click.
A friend of mine that is a mechanic thinks it dropped a valve. He recommends taking the head off and see what the damage is. Any opinions if this is the right next step? Thanks
Old Sep 27, 2015 | 01:34 AM
tubeman426's Avatar
tubeman426
The gear on the crank that drives the cams may have sheared the key and slipped causing the cams to go out of phase, which would have likely bent some valves. I would do a leak down test to see if you are loosing air past the valves. Look in the spark plug hole with a scope see it there is damage visible. I had this happen to a customer of mine, it broke the intake valve off in the front head and imbedded it into the piston.
Bulldog1085
Shovelhead
13
Sep 12, 2022 02:26 PM
trike1946
Apr 18, 2019 08:56 AM
bstacey
Carburetor Related
Nov 23, 2014 04:57 PM
phattey
Shovelhead
Jan 24, 2010 08:45 AM
Beetle1122
Ironhead
Jun 13, 2008 08:55 PM
