Disappointing dyno run
Old Sep 26, 2015 | 05:23 PM
Roadflyer's Avatar
Roadflyer
Default Disappointing dyno run
The bike is a 05 Roadking 95", SE heads, 10-1, Andrews 54's and Rinehart true duals.
Tuned by me with powervision and autotuned to a tee.
I was bored and thought I would ride 50 miles to the nearest dyno today.
I told my buddy that I thought the bike would do 93hp and 95 tq just to see how close I was.
Well, the dyno guy's printer wasn't working and I didn't have my glasses on and couldn't see the dyno screen. I was shocked when he told me 82hp!!
I got him to email it to me and I just got home to look at it.
I know he cranked the bike all the way to the 6200 limiter but the dyno chart only goes to 5200. (we never bothered with fuel mixture readings, this was just a quick hp and tq reading)
I'm not sure how this happened or what the real numbers should be.
I emailed him and I'm waiting for a reply.
Old Sep 27, 2015 | 07:32 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Thats a nice torque curve and I'm sure that the hp probably topped out at 88 if it were to continue to show the curve. Are your heads stock? With some head work you should reach those numbers 95+ and more without a problem.
Old Sep 27, 2015 | 10:23 AM
Roadflyer's Avatar
Roadflyer
The heads are screamin eagle.
I welded a couple of extra baffles in the Rinehart pipes to tone them down a bit, I'm sure that cost a couple of hp. I'm also sure a pro tune would help it out some.
Old Sep 27, 2015 | 01:27 PM
djl's Avatar
djl
Which SE heads; there are several; need a PN.
EDIT: The motor has not been tuned and before you hit the panic button, spend the money for a proper dyno tune. The chart you posted does not show AFR readings and is pretty useless without them. Post the PN for the SE heads so we know what you are working with.
Old Sep 27, 2015 | 02:26 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
The Rineharts are also killing your numbers but you probably already knew that!
Old Sep 27, 2015 | 05:24 PM
Roadflyer's Avatar
Roadflyer
The front head is #16827
Before I spent the money for a proper dyno tune, i'd have to find someone I trust to do it. Clearly not the guy I went to. I never even got a proper dyno pull out of him, never mind tuning. Nor has he gotten back to me about the mistake.
Maybe Jarz in Vancouver-250 miles away. Too late in the year to ride Mountain passes.
ever see Discovery channels "Highway Thru Hell"? A little early in the season for snow, but that's my road.
Old Sep 28, 2015 | 05:32 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
JARZ should be able to put a good tune on that.
Scott
Old Sep 28, 2015 | 07:59 PM
jm35ny's Avatar
jm35ny
Looks pretty good!
Old Sep 28, 2015 | 09:03 PM
joe98's Avatar
joe98
Road flyer ; I just saw you're from B.C. Your fortunate enough to have a very well respected and talented tuner out there. Russell Inglis of Lonewolf Performance. I believe he's in Nanaimo or Kamloops ? I'm from Toronto,Ontario ; if I was even a 1,000kms from there I'd ride out there tomorrow. I had my dealer build and tune a simple 107 kit without head work, that was supposedly easy to tune. Well, after 3 attempts to get it right I finally gave up. Give Russ a call, he will set you up. Good luck !!
Joe
98hotrodfatboy
Engine Mechanical Topics
18
Sep 1, 2015 09:06 AM
GWD1983
15
Aug 31, 2014 09:27 AM
ultraclassic53
Nov 17, 2012 08:36 PM
Sath
Mar 14, 2010 10:32 AM
07fxdwg
Feb 2, 2008 02:04 PM
