Please help! Lifter question
Old Feb 1, 2016 | 12:12 PM
Steve_m's Avatar
Steve_m
There was no sound at all. The bike just died
Old Feb 1, 2016 | 12:17 PM
Steve_m's Avatar
Steve_m
Also, I saw my oil pressure gauge drop off, and by the time I reached the ignition to kill the bike, it already died. So did all the pressure just go because that lifter dropped down that low??
Old Feb 1, 2016 | 01:01 PM
Campy Roadie's Avatar
Campy Roadie
I'm basing the oil starvation theory on the fact the lifter for the #2 cylinder looks rusty (maybe it isn't). No lifter with sufficient flow could ever rust in my opinion. What does the lifter bore look like on the #2 cyclinder? (The front)
Old Feb 1, 2016 | 02:46 PM
djl's Avatar
djl
That's one nasty blowout but pretty sure that lifter bore can be repaired. IIRC, Kirby/VeeTwin Performance and forum sponsor does these kinds or repairs. If not, there is a guy on HTT forum that does.
Old Feb 1, 2016 | 06:00 PM
Steve_m's Avatar
Steve_m
No that's not rust. Just looks that way
Old Feb 1, 2016 | 06:17 PM
Campy Roadie
What is it?
Old Feb 2, 2016 | 10:35 AM
Steve_m's Avatar
Steve_m
Just the way the picture came out. There's definitely no rust
Old Feb 2, 2016 | 09:00 PM
Steve_m's Avatar
Steve_m
Ok so I did some more looking into it. I can slide a good lifter into that bore and move it freely with a cam (no play/lash). There is some scoring in the lower part of the bore, but it moves easily, so as long as it will seal oil pressure below where it enters the lifter it should be all good right? (Not talking about possible damage elsewhere)
Old Feb 3, 2016 | 04:25 AM
Campy Roadie
I'd look up the lifter bore tolerances and measure yours. They do make over sized lifters should yours be out of spec.
Old Feb 5, 2016 | 01:03 PM
fattyboyy's Avatar
fattyboyy
I would have all four lifter bores bored out and sleeved and maybe pined in place. If that is possible.
mischief
Engine Mechanical Topics
Sep 4, 2016 01:12 PM
Johnboy77
Oil Archive (no new posts)
Aug 22, 2015 08:16 PM
Johnboy77
Aug 21, 2015 10:25 PM
BettyAnn
14
Nov 24, 2014 05:46 PM
Rubber Slinger
Exhaust System Topics
Jun 20, 2011 10:23 AM
