Evo trouble
Old Feb 17, 2016 | 11:31 PM
Larry Henry's Avatar
Larry Henry
Stage I
Default Evo trouble
I have a '98 evo , pistons are turning , but the pushods ,ign. Sensor, lifters , cam isn't . what do ya think ? Pinion gear ?
Old Feb 18, 2016 | 02:38 AM
TIMROCKIN's Avatar
TIMROCKIN
Stage II
off top of my head it would have to be .
Old Feb 18, 2016 | 05:56 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Straight-designed pinion shaft could very well be broken.
Scott
Old Feb 18, 2016 | 06:41 AM
prodrag1320's Avatar
prodrag1320
seen it happen more than once (or twice),hope its just the gear,but ill bet its the shaft.what ever it is,make sure you check the valves.they are probably bent (valve train quits moving,pistons still moving = bent valves)
Old Feb 18, 2016 | 10:52 AM
TIMROCKIN's Avatar
TIMROCKIN
Stage II
Very good advice guys , if shaft broke then more broke with it .
Old Feb 19, 2016 | 07:31 AM
Hillsidecycle.com
Sponsor
Usually the valves will be wadded up also.
Scott
mikeyhd
Shovelhead
Sep 25, 2017 07:22 PM
motorwolf
Jun 5, 2011 09:52 AM
motorwolf
Exhaust System Topics
Jun 4, 2011 08:55 PM
cthecope
Dec 5, 2010 10:00 PM
graultytc88
Shovelhead
Feb 15, 2008 03:27 AM
