View Poll Results: Did you install your Gear Drive cams
I put them in and checked backlash. Standard gears were fine.
40.00%
I put them in, but needed undersize, oversize gears
13.33%
I put them in but didn't check backlash
6.67%
Had them done. Standard gears were fine
13.33%
Had them done and needed undersize or oversize gears.
0%
Bought bike with them already in
26.67%
Voters: 15. You may not vote on this poll
Poll: Geardrive cams, do it yourself?
Old Mar 13, 2016 | 01:48 PM
GoofySB's Avatar
GoofySB
Default Poll: Geardrive cams, do it yourself?
After seeing many posts recommending gear drives and somewhat reading the installation procedure I am curious how many did it themselves and how many actually needed an undersize or oversize gear.
Old Mar 13, 2016 | 06:13 PM
2013_FLHTK's Avatar
2013_FLHTK
Put them in 3 88" twin cams. Very little run out, standard gears were a perfect fit.
Old Mar 25, 2016 | 08:10 PM
Brian Kelley's Avatar
Brian Kelley
Just put the S&S 510G geared set in my 2005 FLSTN Deluxe. I measured the runout with a $35 dial gauge from Harbor Freight. It was well under .003" or whatever the limit was.
They run great.
Old Mar 26, 2016 | 09:27 AM
dfwhockey17's Avatar
dfwhockey17
In the 20+ sets we have done at the shop we have only had to use under/over gears 3 times. We have also seen a handful of bikes that had more than .003" runout and set them up with the hydraulic chain system...
producer
Exhaust System Topics
May 1, 2013 06:13 AM
Gooch
May 26, 2012 02:08 PM
Road King Kid
Dec 24, 2009 10:55 AM
broke joker
Apr 3, 2007 08:40 PM
jmedn
Aug 31, 2006 11:36 PM
