Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have a knocking noise coming from the T B at idle. If I crack the Throttle and raise the r pms by 100 or so the noise goes away.
I have read that it's common and also had a well known Builder /dyno guy tell me the same, that it's Just throttle body get used to it.
Has any one come up with a fix yet
Running the stock a.c. cover will mask some of that sound.
