Tc96b build advice
Old Apr 17, 2016 | 03:01 PM
09_NightRider's Avatar
09_NightRider
Default Tc96b build advice
Got a stock tc96b with 4300 miles.
Want to beef it up before I installed it.
Absolutely zero experience with twin/cycle engines. However I'm mechanically inclined and want to learn.
I want more power in the low to mid range area, 99% of my riding is less than the 100mph and usually around town or short road trips (4-6 hours) 1way.
Need advice on a good combo,
Heads (cc's/valve sizes/flow rate)?
Cams (specs for head)
Bigger bore size
anything else?...
Advice on where good deals can be found as well...
What specialty tools I need?
Inner cam bearings remover/installer?
Anything else?
I have a pcV for tuning.
I have hooker trouble makers exhaust
Stage 1 Free flow with k&n filter intake
Going to start collecting parts soon.
Thanks
Old Apr 17, 2016 | 03:10 PM
Lambda's Avatar
Lambda
Take a look at the fuel moto 107 kit with either the tw 555 cams or tw 777 with headwork, lots of torque and easily +100 rear wheel hp
Old Apr 17, 2016 | 05:53 PM
grbrown's Avatar
grbrown
We have several builders who can advise on this, who have well established and proven combinations of parts, which they add their own skills and expertise to. Fm is one, Hillside Cycle is another. They can both port your heads ann supply all the parts you need. Give one or both of them a call.
Old Apr 18, 2016 | 07:19 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Bigger bore size
anything else?...
Anything else?
Thanks
Happy to lend a hand.
Scott
Old Apr 18, 2016 | 09:03 AM
09_NightRider
Thanks for suggestions guys.
I actually dealt with fm before (pcv).
I will call today, but hillsidecycle.com just gets me a blank page..?
Old Apr 18, 2016 | 09:18 AM
PapaThiele's Avatar
PapaThiele
I noticed this last week as well. Thought maybe it was a maintenance thing.
Old Apr 18, 2016 | 10:01 AM
stogieluvr60's Avatar
stogieluvr60
Default Suggestions...
Bigger bore size
anything else?...
Anything else?
Thanks
What bike is this going in? Your riding style doesn't appear to be very aggressive so I can't imagine why you would want a high HP/TQ motor...just a kick in the pants for that anemic 96"er...on the cheap..a set of SE255 cams off E bay would set you back about $100 and would provide a nice boost in the low to mid range where you say you want it. Anymore than that and it starts getting expensive....how much money do you have to spend? Where do you want to end up?
Old Apr 18, 2016 | 10:05 AM
stogieluvr60
That's God doing you a favor...I have an inner cam bearing puller/installer you can borrow if you want...I'd get compression releases put in those heads now...manuals work for me...better to have them and not need them than need them and not have them...better plan on changing out the compensating sprocket if it hasn't already been done...beef that motor up much at all and the stock comp will fail...guaranteed. Lots to consider when you plan on bumping up the motor..all other systems have to be considered...if you don't address the weak links now, you will later...and it's usually when you can least afford it...been there..done that...
Old Apr 18, 2016 | 10:30 AM
grbrown's Avatar
grbrown
Red face
Strange but true! Scott's phone number is above.....
Old Apr 18, 2016 | 10:36 AM
stogieluvr60
Default A valuable asset
Here is a link to a guy I trust completely...a consummate professional (& a bit of a mad scientist)...did my heads for me and many others....JC knows his stuff.
http://jwperf.com/
