How to make my Shovelhead "cackle" when I pull the clutch in??
Old Apr 30, 2016 | 12:51 PM
colton1947's Avatar
colton1947
1st Gear
Default How to make my Shovelhead "cackle" when I pull the clutch in??
What makes the engine do this? Is it stiffer valve springs? Larger valves? Higher than stock compression? The bike currently has a Andrews A/B grind cam and is bored .30 Over stock, engine is a 1976. My dad has a 93 ci sidewinder Shovelhead I believe and it sounds like a fire breathing dragon when he pulls in the clutch. Lets face it Harleys are about appearance and show, when I finish building my bike I want it to make this sound. Someone please tell me how. Thank you in advance for any and all advice!
Old Apr 30, 2016 | 12:53 PM
Dave15's Avatar
Dave15
Here we go......
Old Apr 30, 2016 | 12:58 PM
Shanebo's Avatar
Shanebo
Straight pipes will do it.
Whoooom-Baaaaahhhhhhhhhhhh!!!!!!!
Shane
Old Apr 30, 2016 | 01:09 PM
colton1947's Avatar
colton1947
1st Gear
Its running 2" drag pipes now and doesn't do it unless I run the RPMs up high as hell, will switching to 1-3/4 make that much difference? My dads shovel cracks when you pull the clutch in even if your only at 1k or at any speed in any gear, I think there is more going on than just pipes. His bike also hauls A$$ and he is running 2" straight pipes as well so what's the difference here?
Old Apr 30, 2016 | 01:34 PM
Uncle Larry's Avatar
Uncle Larry
Old Apr 30, 2016 | 01:45 PM
cdonis's Avatar
cdonis
Lmfao, high compression, and lots of overlap seems to do it
Old Apr 30, 2016 | 01:48 PM
Stiggy's Avatar
Stiggy
1 3/4" will cackle better than 2" pipes. Equal length, about 38".
Old Apr 30, 2016 | 02:02 PM
colton1947's Avatar
colton1947
1st Gear
Random video I found of the sound I am talking about. Thanks for the constructive advice! But I think there is more going on than just exhaust, my dad says its higher performance heads with bigger/ stronger valve springs stopping the flow of the fuel, basically like a "controlled" backfire. Just wanting someone to confirm this or tell me, no its "this, this, and this" before I start spending money. Also does anyone know a reputable shop to work on my heads?
Old Apr 30, 2016 | 04:57 PM
Shanebo's Avatar
Shanebo
Like in that video, you might want to be following your bike while someone else rides it, and see how it sounds from there.
Bikes don't sound the same from every perspective.
My old ironhead sportster chop made that noise all day long, .030 over pistons, 1 3/4 drag pipes, slash cut.
Shane
Old Apr 30, 2016 | 09:15 PM
Sierra977's Avatar
Sierra977
Backdrag the pipes is what you mean
This is cackle
ETA the cars putting on a flame show have a fat pill in the injectors
