Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Can you use stock pushrods with Andrew's cam can you use stock pushrods with Andrews cams
Depends on the cam, whether or not heads are decked, head gasket thickness; basically the valve train stack up height. I hope answering once is enough..............
Sorry about that sometimes these phones have a mind of there own.
What I meant do they have the same base circle as Harley stock cams.
I was under the impression that Andrews uses a slightly smaller base diameter than the stock cams. I think that what DJ and others will tell you is that by the time you figure in all the tolerances and thermal expansion you are better off using adjustables so that you can get them set correctly.
"Andrews Products 2006 Dyna and 2007 and later twin cam engines use use stock size lobe base circles for lower lift, bolt in type cams.For these cams the stock pushrods can be reused. ....Mark the pushrods so they can be replaced in their original locations since not all stock pushrods are the same length."
That said I have heard the smaller base circle comment also.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
That said I have heard the smaller base circle comment also.[I][B]
The operative words in the above quote are "bolt in type cams"; which cams are those? The "bolt in" term used to apply to cams with lifts that did not exceed .510"; however, with the introduction of beehive springs in 2005, cams with lifts up to .570" became bolt in cams. So, considering the Andrews 57 would be a bolt in cam, it does have a base circle .020" smaller than stock so the quote from the Andrews website could be considered misleading. A .020" base circle increases the stock valve train stack up height by .010"; some run OEM pushrods with no issues and some have noise. Factory tolerances come into play here. Now consider heads are decked .030" and a .030" head gasket is used which reduces the valve train stack up height by .045" less the .010" increase via the base circle and now OEM pushrods will preload the lifter to about .135", still OK by me.
I think it is important to consider all clearances when deciding whether or not OEM pushrods or adjustables should be used as well as the individual bias for one over the other. JMHO...............
FWIW those instructions came with my 57h cam for my '15 Limited, .550 or .560 lift I think.
Understood; not starting a debate but making a point. Just saying that the bolt in terminology is hazy, that's all. The 57 does have a smaller base circle, smaller by .020". As I said in my previous, some run that cam with OEM heads, gasket and pushrods with no issue but some have a noisy valve train. Factory stackup tolerances come into play here; note the Andrews quote advice to mark the pushrods because "stock pushrods are not the same length". The same can be said for cylinder height or any other dimension that affects valve train stack up height. So, for those reasons and the fact the I prefer more lifter preload than factory, I would be running adjustable pushrods but that's just me............
No issues for me with OEM pushrods providing the valve train stackup height will preload the lifter to .125"-.135" with OEM pushrods; that makes sense.
That's the smart thing to do anyways. With adjustables you can get to your cams without removing the heads and everything else if ever needed to in the future.
