Oil dripping off clutch cable? Help
Old Jul 18, 2016 | 12:22 PM
rdc401's Avatar
rdc401
Check cable is not too close to exhaust could melt hole in cable and it will leak that why mine was leaking a while back
Old Jul 19, 2016 | 06:54 AM
elky72ss454's Avatar
elky72ss454
If vent is clogged pressure will build inside the tranny forcing the fluid up the cable causing it to leak. I have seen it many times. All the info I have for ya...Good luck!
Old Jul 19, 2016 | 08:08 AM
wideglideCVO's Avatar
wideglideCVO
Thanks to all for the good information>:
Old Aug 2, 2016 | 01:10 AM
Rocker B's Avatar
Rocker B
Originally Posted by wideglideCVO
I changed the o ring on my clutch cable over the weekend going into cover and drained a fair amount of transmission fluid out of the clutch cable. Checked to make sure the breather house for transmission was clear. Took it for a ride and checked cable under the engine and it had a drip on it again. I will check it again today, maybe it was just residual fluid left in the cable?
Did the o ring fix the problem, was it residual fluid?? I just noticed a small drip on my Rockers clutch cable....
Old Aug 3, 2016 | 06:10 AM
wideglideCVO
New o ring did not fix the problem. Don't think it is residual?
Breather tube is also clear, cable is not rubbing anything. May wind up replacing the cable its getting old. Don't know what else to do.
Old Aug 3, 2016 | 06:22 AM
Scudda's Avatar
Scudda
My clutch cable that is attached to the transmission housing is discolored, yellowish and it is leaking little drips under the engine off the clutch cable. Do you think it is the o ring inside the transmission cover? If I open the cover should I drain the transmission first. I dont know how much oil will come out if I don't drain it first.First time. Need advice.
Mine did the same thing...I needed to replace the cable.If oil is inside the cable it will need to be replaced
Old Aug 3, 2016 | 11:10 AM
wideglideCVO
Thanks I probably will replace.
Old Aug 11, 2016 | 10:31 PM
yank721's Avatar
yank721
Just a heads up, my bike did the same thing, thought it was leaking too. Happened to be cleaning all the oil off the cable to see exactly where it was coming from. Checked it the next day and damn there was another quarter size puddle of oil on the floor but when I checked my cable at the housing it was bone dry. Turned out the oil filter was just looks enough that it was leaking a little bit and running down the cable. I wouldn't believe it if it hadn't happened to me since it looked like it couldn't have run that far up the cable but it did. It's worth a shot to look
JuanderBoy
Oct 30, 2019 11:23 AM
fatboy slim
Dec 4, 2014 07:37 PM
dickey
Jun 9, 2012 06:05 AM
LOOPNERS
Oct 14, 2007 10:22 PM
deadite84
May 17, 2007 11:59 AM
