Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So in the fall I am replacing my cams, tensioner shoes, having the cylinders bored to 98 and having stage 1 headwork done.
I have an 05 FLSTSC (springer classic)
What special tools will I need? I already have the shop manual and I plan on getting an inner cam bearing installer/remover. I have torque wrenches both ft/lb and in/lb and a very good tool box. I also have the CYCO tensioner shoe jig and the new shoes. I also already have the Torrington B148 inner cam bearings.
Do I need special tools like the snap-on dog bones for the rocker boxes?
What is the best option for the outer cam bearings in the cam plate? Take it to a shop to have cams/bearings pressed out and new ones pressed back in or is there another way?
Any tips/help to prevent me from making mistakes is greatly appreciated!
Watch the videos from Fuel-Moto . I'm pretty sure that they show a line-up of all the tools that they use. The videos are on their website and maybe Youtube as well.
Thank you sir for the tip. I will check out the videos.
Thanks,
James
Who's doing the headwork & cylinder boring? Ask them if they will borrow the needed tools,thats what we do if we`re doing the work
The shop that is doing the work is in another state and I will be mailing my heads and cylinders to them for the work. I doubt they would lend me the tools but you never know.
Thanks for the link and help. I have seen the caveman method and knowing my luck I would F*!K it up but if that is what I have to do then that is what I have to do.
When I was a diesel mechanic in the Army we always used a brass drift to knock out bearing races and install new ones but those were heavy duty.
Might want to check,like i said,we do and all our work gets shipped here
