Cam bearing tools - help
Hoping those with experience can chime in!
1. Inner cam bearing install tool:
http://www.ebay.com/itm/141866040891...%3AMEBIDX%3AIT
2. Inner cam bearing install tool:
http://www.ebay.com/itm/310806772010...%3AMEBIDX%3AIT
3. Inner cam bearing install tool:
http://www.ebay.com/itm/131634279842...%3AMEBIDX%3AIT
4. Support plate removal/installation tool:
http://www.ebay.com/itm/112058627106...%3AMEBIDX%3AIT
Use the oven/freezer method to install the outer cam bearings. Freeze the bearings over night, heat up the cam plate in a 300* oven (remove the plug with o-ring at the top of the cam plate first) for about 20 minutes. The new bearings will drop right in.
Depending on cam choice, the OP may need a hydraulic press to push the gears on the cams.
http://www.heartlandproducts.net/hea...m-bearing-set/
I have no doubt that a blind puller would work well. I don't have as much experience working on Harleys as some of the members on this forum. For me, this tool made sure the job was done right the first time.
Garrman
Garrman
Amazon had them. About $130-140. It has everything. It's an oem kit for the HD part #.
I bought a 20ton press from harbor freight for tranny work, and it worked perfectly for the cams and bearings.
Many of these parts are made from various heat-treated alloy steels and putting too much heat to them will destroy the physical properties.
I've recently done a cam swap and IPB replacement and had to buy tools for both jobs. I will probably never use them again but at least I didn't screw anything up by trying to finagle some tool to do a job it was not intended to do.
