Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
2009 ultra
current mods:
freedom performance 2" stepped head pipe
cfr 1.75 mufflers(made a reducer)
Parts for build
s&s 106 kit
S&S 89 cc heads( .640 maximum lift, 2" intake/ 1.605 exhaust valves)
.03 head gasket for aprox 10:1 compression
Looking for torque/power in the 1700-4500 range which is where i mostly ride, however if a certain cam selection is better for my setup riding rpm range could be adjusted.
cams im looking at (bigboyz calc)
T-man 555 torqster-9.33:1 ccr and 196 ccc
cyclerama 575-9.41:1 ccr and 196 ccc (tuner has never used this cam and suggested other, putting it out here because of targeted 9.4 ccr and 195ccp)
I've read these 3 cams are all very similar
drago 580 -cam(not in the calc)
kuryaky 24d- cam(not in the calc)
andrew tw57- 9.3:1 ccr and 193.1 ccp
Im not looking for a big dyno number, just better rideability at a reasonable cost. Are these cams all going to produce similar numbers at different rpm ranges? Are they all going to me similar? Or could someone give me a good idea of what to expect from the t man 555 vs the drago/etc style cam id greatly apreciate it.
I used to have woods 555 cams in my stock 103. I switched to woods 999-6A and think that cam has a broader torque curve. Just something else to think about.
We have the original version here as well as that one.
Also, Cam Analyzer, Quartermaster, and Quartermaster Jr.
Gives a good idea as to what to expect.
Scott
107"
touring porting on your OEM castings (the S&S heads are better suited for higher RPM builds,1.900-1.575 valves using your castings will work much better for what your looking for)
S&S .583 cams set @ 9.8-1
we`ve done this build many times on touring bikes with very nice results
We stock Wood, Cyclerama, Andrews, S&S cams are all here in our arsenal.
Also Comp, original Sifton, Lieneweber, Dave Makie, and Crane, on the shelves.
Even a couple S/E cams.
Pick and choose where we need to go once we go over the particulars with the bike owner.
Scott
