P0051 & P0154 Codes
Old Sep 5, 2016 | 02:41 PM
jobibreakout's Avatar
jobibreakout
Stage II
Default P0051 & P0154 Codes
Running into a really odd issue.
Setup:
2016 Softail Breakout
V&H Big Radius Pipes
V&H FP3 Tuner with canned map (autotune off)
Started throwing codes P0051 (Rear HO2 heater low/open) and P0154 (Oxygen sensor high/open rear) codes. I replaced the rear O2 sensor and put a new crush gasket on the rear pipe, but I'm still seeing the same codes. The check engine light will come on when accelerating and go off when idling at a stop light or when coasting downhill with no throttle. I've been running the pipes and tune for almost 4K miles with no problem. I used new gaskets when I installed the pipes.
I thought for sure it was a bad sensor or an exhaust leak. I'm totally stumped at this point. Has anyone seen this before, or have any ideas? Also, I'm supposed to leave for a road trip this week. My better judgement tells me not to ride the bike for long distances in this state because it may cause the rear to run too rich? Any insight would be greatly appreciated.
Thanks,
Jed
Old Sep 6, 2016 | 12:44 PM
hrdtail78's Avatar
hrdtail78
Did you depin the connector to get it though the oil tank? Are the pins in the right position and seated correctly? I would also check the pins going to the ECM. It is pin 15 on one plug and 17 on the other.
I know it is a new sensor and should work but I wouldn't take that for granted. You can switch the sensors front and back and see if it follows. They are the same just different plugs on them that are easily switched.
Old Sep 13, 2016 | 09:59 PM
Ed Ramberger's Avatar
Ed Ramberger
Switching the sensors will cause cylinders to peg rich/lean because the ECM will be causing a read on a cylinder controlled by the other cylinders injector.
Old Sep 14, 2016 | 07:55 AM
hrdtail78's Avatar
hrdtail78
Not what I meant. Remove the front sensor, and put it in the rear location and hook it to the rear connection. Remove the rear plug and install it in the front location and hook it to the front location. I am suggesting to just swap the sensor. This is why I mentioned switching the connectors so back would still be black.
If the problem follows the sensors. ding, ding, ding. If the problem stays with the cylinder. It's not the sensor.
fhartell14
May 31, 2019 04:02 PM
Stang951
Oct 12, 2018 02:41 PM
EJP777
13
Jan 26, 2018 11:14 AM
deezy139
Aug 19, 2014 10:05 AM
nomad20012
Jul 20, 2010 05:47 PM
