Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I've been reading for hours on this and it's hard to get a clear answer...
I installed new pipes and high flow air cleaner, had the bike tuned at HD via a download. Worked good for 10 min, then I get a check engine light and the error codes :
P0151 Rear Oxygen Sensor Low
P0154 Rear Oxygen Sensor Inactive
bike still runs ok but I want to fix this. I did not put new pipe gaskets, just reused the originals, so I am considering a leak but Does anyone have a suggestion?
Perhaps swap the front to the rear and the rear to the front and see if the problems moves with it.
If it does then it probably is a bad/damaged sensor.
I have seen them get damaged during removal if they were tight.
My first guess would be you have a leak on one pipe and you crushed the wrap on the connector on the other cutting off the reference air supply. I can't really decide which would be which.
