Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
No heat issue whatsoever.
BTW, we have that same bike in currently, going from 103" to 107".
Lifter roller failure raised hell, causing the rebuild.
Scott
hillsidecycle they say your the best but I'm not close to you have a question. Just put in the S&S 107 kit with 585 cams adjustable pushrods rocker arms lifters fueling HP oil pump and cam plate. Having over heating problems not getting all the power when I turn the throttle and finding flakes in my oil please help.
Reason: hill side cycle
