Bigger injectors=new tune?
Old Sep 23, 2016 | 05:07 PM
hd_rolling's Avatar
hd_rolling
Originally Posted by qtrracer
Whom ever wrote that 5.3's were only good for 120hp was incorrect for whatever reason.
It's from the Harley screaming eagle parts catalog.
5.3 23% more than Original equipment injectors. Recommended for use with engine configurations making more than 100 rear wheel horsepower.
6.2 grams/second, 59% more than the Original equipment injectors. Recommended for use with engine configurations making more than 120 rear wheel horsepower.
Old Sep 23, 2016 | 05:26 PM
hd_rolling's Avatar
hd_rolling
Thanks for all the advice.
Old Sep 24, 2016 | 12:27 AM
Next In Line's Avatar
Next In Line
Parts catalogs are meant to sell products, not give accurate information.
Old Sep 24, 2016 | 07:57 AM
hd_rolling's Avatar
hd_rolling
I agree, but many of the big name builders use this chart as a guide, and to try to stay under 80% duty cycle
3.91 are good for about 50 Hp per injector
4.35 are good for about 55 Hp per injector
4.9 are good for about 62 Hp per injector
5.32 are good for about 67 Hp per injector
6.2 are good for about 79 Hp per injector
6.7 are good for about 85 Hp per injector
Old Sep 24, 2016 | 09:23 AM
Next In Line
I have a 124" with a 55/58 throttle body and 5.3g injectors. I bounce off the rev-limiter on a regular basis and don't see a need upgrading to a bigger throttle body and/or injectors. I will hit the speed limit long before I hit the 80% duty cycle. If I get close to the 80% duty cycle, then I shift gears.
If I do hit the 80% duty cycle in 6th gear, I would be more worried about the police chasing me and the motorcycle not falling a part than saying to myself "Gee, I guess I should have upgraded the throttle body & injectors".
Old Sep 24, 2016 | 05:25 PM
qtrracer's Avatar
qtrracer
At what psi? Most quote at 42, we run 55-62
kidd.roadglide
Jul 6, 2018 01:10 AM
blankline9
2014-2024 Touring Models
35
Sep 24, 2017 05:21 AM
GregGillette
The Dyno Room
Nov 16, 2016 07:58 AM
sg2007
Feb 27, 2015 12:12 AM
GasCan
May 31, 2007 11:01 AM
