How to remove shaft from rocker assembly
Old Oct 5, 2016 | 02:46 PM
Road Star's Avatar
Road Star
Default How to remove shaft from rocker assembly
I don't have access to my shop manual.. Can anyone tell me. Do I need to press these out?
Old Oct 5, 2016 | 03:23 PM
Lambda's Avatar
Lambda
When my rocker support broke in half i got them out with a rubber hammer and a plastic chisel, sometimes they can be a PITA to get them out, some are a bit stuck, other just slide out with ease.
Old Oct 5, 2016 | 03:40 PM
ROCKOUT Rocker Products
Sponsor
As mentioned above, nothing holds them in except the cross bolt holding the support down. If you have the pressure off the rocker arms they should push out. Some bikes with some miles on them then shaft ends can get kinda "glued" into the supports, but they should still tap out fairly easily.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Oct 5, 2016 | 04:17 PM
Road Star's Avatar
Road Star
Ok. Thanks for the info. Just want to get these apart and see what's going on inside there.
Old Oct 10, 2016 | 11:46 PM
Wv7o's Avatar
Wv7o
If you are taking out the rocker shafts, might as well order a set of Rockout rocker shaft inserts for when it goes back together.
Old Oct 11, 2016 | 01:25 PM
Ed Ramberger's Avatar
Ed Ramberger
Tap them out toward the side with the retaining bolt. That way the notch in the shaft is out and the rest of the shaft passes through the bushings easier.
1984 flhs
Shovelhead
24
Oct 30, 2018 09:00 PM
flimon
Engine Mechanical Topics
Aug 23, 2016 01:26 PM
rottnutz
Aug 14, 2016 10:13 AM
89FLHTC
EVO
13
May 19, 2016 06:04 PM
texashillcountry
EVO
Mar 25, 2012 09:33 PM
