Cam install Fail!
Old Oct 17, 2016 | 02:31 PM
rauchman's Avatar
rauchman
Originally Posted by bwoltz
I would bet pump assembled wrong.. Seems to happen a lot for first timers..
Oil pump should be assembled in the following order.. Fat gerotors, plate, wavy spring, plate, thin gerotors..
Yup, this is what happened to me as well. Wound up shattering the gerotors and had to purchase a new oil pump.
Old Oct 17, 2016 | 03:23 PM
02Deuces's Avatar
02Deuces
You'll like those 509's when you get it back together. I ran them for a couple of years in my Deuce (also an 88)...Tons of mid range torque, and a nice lope.
Here is what mine sounded like with the 509's
Old Oct 18, 2016 | 09:57 AM
Lunchboxx's Avatar
Lunchboxx
It was the oil pump once I opened it up and I corrected the problem put it back together and its great! Love the cams. I used the S&S adjustable Pushrods and S&S lifters. I used 21 flats on the adjustable rods and the valves seem noisy still. Should I put a couple more flats on it? 21 equals 3 and a half turns.
Old Oct 18, 2016 | 10:27 AM
GalvTexGuy's Avatar
GalvTexGuy
Subscribed.
Old Oct 18, 2016 | 10:56 AM
Lunchboxx's Avatar
Lunchboxx
Just reading https://www.sscycle.com/tech-info/in...rod-adjustment
seems 24flats(four complete turns) is whats called for.
Old Oct 18, 2016 | 11:05 AM
djl's Avatar
djl
If those pushrods are 28TPI, 21 flats or 3.5 turns would set preload at .124"; I would go to 4 turns if the pushrods are 28 TPI and not 24 TPI. However, before you do that confirm that the pushrods are 28TPI.....
Old Oct 18, 2016 | 11:08 AM
Rocker B's Avatar
Rocker B
Yep... I have a set of S&S cams sitting here waiting to install in my Rocker. The instructions with the cams say "S&S adjustable pushrods have 32 threads per inch, and 24 flats (4 full turns) will place the pushrod in the optimal position of the stock tappet"
Old Oct 18, 2016 | 11:23 AM
djl's Avatar
djl
If the pushrods are 32TPI, 4 turns will set preload at the same place 3.5 turns on a 28TPI pushrod; about .125". If valve train is not quiet at that preload, set preload at about .140"-.145". Verify actual TPI before making that adjustment.
Old Oct 18, 2016 | 11:45 AM
Jay Guild's Avatar
Jay Guild
Glad to hear you fixed it. Too bad you had to take it back apart but it was better than going down the highway and finding out.
Old Oct 18, 2016 | 11:58 AM
Lunchboxx's Avatar
Lunchboxx
The S&S pushrods are 32TPI So I need 24 flats. I will readjust after work today!
