Cam install Fail!
Old Oct 18, 2016 | 12:33 PM
djl's Avatar
djl
Originally Posted by Lunchboxx
The S&S pushrods are 32TPI So I need 24 flats. I will readjust after work today!
At 21 flats, preload is about .110"; I would expect some noise at that pre load. At 24 flats, preload will be about .125" which might quiet things down. At 26-28 flats, valve train should be quiet. You can try 24 flats and if valve train is noisy, more preload may help.
Old Oct 18, 2016 | 04:07 PM
Lunchboxx's Avatar
Lunchboxx
Stupid question? Does it make anydifference if I do this with the engine warm or cold?
Old Oct 18, 2016 | 04:42 PM
djl's Avatar
djl
No stupid questions here. No, it doesn't make any difference.
Old Oct 19, 2016 | 09:43 AM
Lunchboxx's Avatar
Lunchboxx
Readjusted last night with 27 flats still seems noisy. Maybe I am hearing something else. But it only seems to be noisy when the motor is under load. I cant hear anything at an idle.
Old Oct 19, 2016 | 09:52 AM
djl's Avatar
djl
My all bore 107" motor makes plenty of noise on a cold start; however, when the motor is up to operating temps, quiet. Take a ride, like 50 miles or so and see how she sounds when everything is up to operating temps.
Old Oct 19, 2016 | 10:01 AM
qtrracer's Avatar
qtrracer
Detonation?
Old Oct 19, 2016 | 11:03 AM
Lunchboxx's Avatar
Lunchboxx
I guess it could be detonation but it doesnt really sound like it. But I will check my plugs to see.
Pops98
Feb 1, 2015 05:05 PM
BenRK05
Mar 13, 2014 06:06 PM
davidnewtonparr
Exhaust System Topics
11
Aug 12, 2013 10:16 AM
chidiver
May 17, 2012 11:06 AM
sf657
Apr 30, 2008 09:34 PM
