Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Just a quick update. talked to Scott and he is going to machine the left side case to accept a new stainless steel sleeve that he is going to machine and install. It'll probably have better clearances and stability than oem. I have other goodies as well being done. I think this last motor upgrade should take me to the finish line.... Time to play....
You sure he's using SS for sleeve material? I woulda thought sintered bronze would have been better.
If I under this correctly, what has happened is in the aluminum case bore for the crank roller bearing outer race got loose. Someone makes a SS sleeve with instructions that once you bore the case for a press fit, this sleeve presses in and is also retained by a couple of set screws from turning. So the actual material is not any type of wear material. Just tough since it's is also not all that thick. Know there is a sleeve that face bolts to adapt later model Harley's to the older style bearings I think?
That's the way I understood it. And that part is no longer available or something like that....
