Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I just tore my motor down on my 2010 Wide Glide. It is getting the HD 110" cylinders and piston kit (92500039) , S&S 585 cams and I'm still in the air about heads. Either sending them out or bolting up some S&S 89cc. I just have to figure out if I need to clearance the valve cuts on the pistons or not and where The compression needs to be for these cams. I am thinking 10:1
The S&S .585 cams want 10.5-1 to 10.7-1.at 10.0-1,the results will be very soft low RPM performance and mediocre mid & upper RPM power
so I'm looking to install a big bore kit over the winter but just for labor it's 1500 and parts is 3k I have the book for my bike and I'm very mechanically inclined how hard would this be to do myself I have plenty of time to work on it just curious if it's possible to do by myself
Sounds pricey, kinda'.
We have complete 98", and 107" kits that start as low as $2050.00, with headwork, if you are pulling the wrenches.
If your getting priced with say an HPI t/body, injectors, roller rockers, 2.00" valve heads that'll handle large lift/large TDC's, with a good 2/1 pipe, that could actually be even more than that quote you've received.
Happy to help you with your goals.
Scott
For the $1000 it cost to purchase the S&S heads I'm Sure that Kirby who is not far from you (2 hrs) can match your heads to that cam. It'll make a huge difference...
