Crank runout
Old Dec 28, 2016 | 08:01 AM
2deuceguy's Avatar
2deuceguy
Default Crank runout
What do you guys consider the limit on crank runout for doing a big bore? The last spec I looked up was for a 2011 street glide and that said a max of .012" so at what point do you insist on going through the bottom end ?
Old Dec 28, 2016 | 08:39 AM
HD Pilot's Avatar
HD Pilot
A ton of differing opinions are sure to follow....
I decided to fix mine at .0061"
Old Dec 28, 2016 | 09:07 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If it is say, .005" for instance, and is has stayed at .005" w/o movement, it was probably assembled that way.
Folks are always concerned with the pinion shaft TIR.
We've witnessed many with sprocket shaft issues.
Scott
Old Dec 28, 2016 | 11:11 AM
djl's Avatar
djl
.012" is the "new" runout tolerance for warranty purposes; it was .003" until '07 IIRC. Big bore has nothing to do with it. .003" is considered by many to be the max runout for gear drive cams although I have seen successful gear drive installs on runout of .004"-005". Of course one can run chain drive cams with more runout. The stability of the crank is the determining issue as to whether to address the crank. As Scott points out if runout is .005" and stays there, no worries. However, if .005" and 5K miles later it is .007"; the crank is not stable and should be addressed.
Old Dec 29, 2016 | 06:08 PM
Kingofcubes's Avatar
Kingofcubes
Default run out
.005" is my limit. I always lift up on the pinion shaft against the dial to see how loose the pinion bearing is also because this will give a false reading on total run out. .003" is my limit for gear drive cams.
Old Dec 30, 2016 | 10:43 AM
2deuceguy's Avatar
2deuceguy
Thanks for the responses guys. I've been doing cam changes and big bore kits and such for friends the last few years. i always measure, but the spec in the service manual was all I had to go off of so appreciate the input. I always like seeing what the pros on these forums have to say.
Old Dec 30, 2016 | 11:57 AM
Lunchboxx's Avatar
Lunchboxx
This may seem like a stupid Question, but does anyone have a diagram or picture of a cranksaft with the differents parts labeled, Like what end is the pinion shaft and whats the other side called. Only thing I have done in the bottom end is put new cams in and I just followed the directions that came wit the cams
Old Dec 30, 2016 | 01:06 PM
Campy Roadie's Avatar
Campy Roadie
Pinion shaft is on the cam side (right). Sprocket shaft is on the compensator side (left).
Old Dec 30, 2016 | 01:59 PM
Lunchboxx's Avatar
Lunchboxx
thanks
Old Dec 30, 2016 | 06:23 PM
2deuceguy's Avatar
2deuceguy
Ya know what would be cool to see is an engine building tips and tricks sticky. I'd love to see some of the things the pros do that aren't in the book.
