Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
This may seem like a stupid Question, but does anyone have a diagram or picture of a cranksaft with the differents parts labeled, Like what end is the pinion shaft and whats the other side called. Only thing I have done in the bottom end is put new cams in and I just followed the directions that came wit the cams
currently building my 03 88ci into a 95 and measured crank runout just the other day. Bike has 67,000 on it and runout was .002 needless to say, i was happy with that. Still running chains though. maybe gear drives will be during the next major overhaul
Howdy,
I can't find a thread so I'll post it here. I have a 2017/107 that I have done work on to about a stage II. See signature. I have 55K miles now. I plan on keeping the bike and I'm looking ahead for options. Currently making
107HP / 120 Tq and has not been on a dyno tune yet.
I havent' decide for sure If i will go with big bore kit to 124 or just rebuild stock 107. I do plan on doing a Darkhorse Comp and hedwork. The heads will depend on what I do for the Ci.
My question is about the crank. I haven't done a crank run-out yet. Actually don't have a gauge.
The question is rebuilding the stock crank ( not weld, just rebuild and balance) or getting a after market like S&S.
The S&S is not welded like a Darkhorse, so could be rebuilt it needed down the road.
When I rebuild, I know that is the time to address the crank, bearings, pushrods.
Has any had their cranksahft rebuilt? What are your thoughts?
