Yellow fluid in trans..?
Old Jan 21, 2017 | 01:20 PM
09_NightRider's Avatar
09_NightRider
Default Yellow fluid in trans..?
When I first popped off clutch cover some cappuccino colored fluid was present. Then when I drained the fluid it was clean. Later I pull the cover off again and again distinctive yellow color is now present...
any ideas?
by the way, this is first fluid change, 4400 miles
factory installed fluids, I'm hopping it's just from assembly lube
Old Jan 21, 2017 | 02:38 PM
silveradoman2's Avatar
silveradoman2
It looks like water was in there. Same color I get from a 2001 S&S 88 engine head breather when it drips on the ground. Was told moisture gets in and when it gets hot it looks like that.
Old Jan 21, 2017 | 02:52 PM
09_NightRider
Any time I've seem water in oil based products it's a creamy cappuccino colored, not yellow
also, this fluid seemed to have remained somewhat separate from rest of fluid that I drained?
hvacgaspiping's Avatar
hvacgaspiping
any ideas?
Some prankster **** in your tranny? Oh! That sounds like a completely different thread.....
Old Jan 21, 2017 | 03:00 PM
silveradoman2
In your pic it looks creamy color to me. If it was assembly fluid I would think it would merge with the oil, not seperate like water does. JMO
Old Jan 21, 2017 | 03:53 PM
qtrracer's Avatar
qtrracer
Sure looks like some moisture got mixed in with oil to me.
Old Jan 21, 2017 | 07:49 PM
09_NightRider
Ok guys guess I'll just chalk it up to moisture.
motor has sat for 4 years.
thanks for the feedback.
jim70
Apr 25, 2015 11:23 PM
JMK
Oil Archive (no new posts)
Oct 1, 2011 06:46 PM
Skid Lid
Sep 14, 2011 10:01 AM
JR-Boston
Nov 15, 2009 12:13 PM
a69metsfan
Nov 22, 2007 10:01 PM
