Cam spacers
Old Feb 5, 2017 | 06:31 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
Default Cam spacers
Put my cam plate w the Andrews 48Hs back in.
Outer chain sprockets are out of alignment by .020.
Normal?
1st attempt at twin cam stage 2 for me.
Is it possible I have the spacers swapped? I thought I kept everything separated so everything went back where it came from.
Or just get a spacer .020 over and no worries?
Old Feb 5, 2017 | 06:48 PM
bad tappets's Avatar
bad tappets
The sprockets need to be aligned. If you used all the same parts, then yes something is out of wack. Measure the one you using, then go to dealership and get one 20 over that. They sell a whole bunch of diffent sizes. The spacer on the rear cam should be the .010, assuming you have an '07 or later ('06 & later if it's a dyna).
Old Feb 5, 2017 | 07:02 PM
Rocker B's Avatar
Rocker B
When I installed 37H cams in my Breakout, I needed a new cam spacer. The Andrews cam installation instructions said one would be needed, so I got the set HD sells, but you can buy them separately.....
Old Feb 5, 2017 | 07:06 PM
djl's Avatar
djl
Not unusual for a different spacer with new cams. Measure, get the one you need.
Old Feb 6, 2017 | 09:45 AM
Uncle Fuzzy
Thanks for the info and reassurance guys.
The spacer is indeed.110
Off to Harley for a .130
Old Feb 6, 2017 | 08:16 PM
HDSAE60's Avatar
HDSAE60
Pull in and out on the cam, mine had some play. I tried to split the difference.
Old Feb 6, 2017 | 08:38 PM
Uncle Fuzzy
I'll take a look at that. I followed the specs in the manual. Torque both sprocket bolts to 15 ft lbs and then measure. I did this with the chain off.
My OCD will prolly make me pull the plate back out and recheck everything anyway. Besides I think I'm going to check the crank runout for a baseline.
Was able to get a loaner dial indicator from the shop at work so may as well.
Old May 11, 2017 | 03:59 PM
Thatguy1234's Avatar
Thatguy1234
Stage II
Default I *ucked something up
I have a tc 88 I split cases/ New crank bearings snap rings etc stayed with stock cam plate and cams everything lines up engine rotates fine my one tell that something is wrong, my crank cam sprocket is standing proud of the rear cam sprocket by easily 1/8 of a inch and is way out of spec I did not mix up the rear cam and front cam spacers. Any ideas?
Old May 12, 2017 | 10:13 AM
djl's Avatar
djl
Wrong spacer. Same fix as the OPs, measure and get the correct size spacer. Although, I have to say that "easily 1/8" would cause me to pull apart and check everything before final measurement.
SPARKY01
May 22, 2026 07:31 PM
Dyna7
Jan 6, 2014 12:10 PM
monkey sammich
Jan 31, 2012 03:02 PM
JDB
Aug 7, 2011 01:48 PM
cwilks
Apr 14, 2007 11:36 AM
