What would you do
Old Mar 5, 2017 | 12:41 PM
TwiZted Biker's Avatar
TwiZted Biker
So let me get this right , the guys popped the lower end with only 16K on it with a stock motor and most are recommending he goes bigger?
Yeah I can see that solving the base issue alright.....
Old Mar 5, 2017 | 01:29 PM
msocko3's Avatar
msocko3
If he's already splitting the cases, why not go bigger while split. The cost isn't that much more. I had a crank shift, knew it was going to address it. Found it was a good excuse to build a 120, much more fun than the 95 I had.
Old Mar 5, 2017 | 06:11 PM
djl's Avatar
djl
So let me get this right , the guys popped the lower end with only 16K on it with a stock motor and most are recommending he goes bigger? Yeah I can see that solving the base issue alright.....
Yeah, of course the base issue, the cause for the unfortunate situation must be addressed in the process; goes without saying.
Crank is being replaced so why not stroke the motor now; S&S crank won't cost the much more and free labor. Cases are split so why not case bore for bigger cylinders whether the OP chooses to install bigger bore cylinders or not now, he has the option in the future. Please note that the "go big" crowd did qualify the suggestion contingent on the availability of funds.
galaxyfe
Engine Mechanical Topics
Jun 7, 2015 05:08 PM
gmc
Apr 9, 2013 01:52 AM
Twrguy
Sep 11, 2011 01:01 PM
troop
May 22, 2010 09:31 AM
IndyClassic
Apr 10, 2010 02:12 PM
