Odd valve train,noise after cams install
Old Mar 27, 2017 | 11:08 PM
Heath Fleming's Avatar
Heath Fleming
I did forget to mention that after I adjusted the pushrods again up one flat and ran it, it was shooting black smoke. Hard to say if it was soot coming out or something else. It stopped after I rode it for a bit. I also have the screaming eagle pro race tuner I'm letting it auto tune with. I think I'm gonna try to order new lifters and see if that helps. Just don't wanna sink all my cash into the wrong fix. If I do process of elimination it'll be a race bike before I figure it out cause I'll replace everything haha
Old Mar 28, 2017 | 09:28 AM
Max Headflow's Avatar
Max Headflow
If you changed cams, you need to retune.. You will likely have issues if you don't. It's not likely that changing the lifter preload had any effect, unless you got them too tight.
Old Mar 28, 2017 | 09:43 AM
Heath Fleming
I'm running the 255 tune that Harley had for cams cause they are close. It had the big bore kit on there too putting it to the 103 but I adjusted the bore size back down to 96.7. The injection size was the same so I didn't change anything with that. So far I've got two auto tune runs on it, but I'm worried that the lifters or timing chain are starting to go bad
Old Mar 28, 2017 | 02:36 PM
acip's Avatar
acip
Stage I
I'm new here, I just did a cam change on my 13 SG. Put on Andrews 57H the bike pulls strong and I also added a set of CFR Slip Ons. I noticed after that I started getting a knocking sound from the motor. Any experienced this?
Old Mar 28, 2017 | 04:49 PM
Heath Fleming
is it extra valve train noise or a specific knock?
Old Mar 30, 2017 | 03:35 PM
Heath Fleming
I think I may have solved the problem. I remember too much forward and backward movement on the primary chain main cam. I went and bought some hd cam spacers to keep it seated so I hope this fixes it.
bigdog78
Fuel Moto / Jackpot Mufflers
Jul 9, 2023 02:07 PM
matt_m_72
Jun 22, 2019 09:10 PM
Uncle Fuzzy
Engine Mechanical Topics
28
Jun 26, 2017 05:14 PM
D-wake
Oct 6, 2015 02:56 PM
mlrailguy
Jun 12, 2012 06:04 PM
