Not Idling
Old Mar 27, 2017 | 01:22 PM
huskers1960's Avatar
huskers1960
3rd Gear
Default Not Idling
Hello everyone, first time posting. I have a 2006 CVO Ultra. Pretty stock, just a small cam change a year or so ago. Lately when I'm out riding and come to a stop sign, sometimes it will not idle and dies, other times it idles fine. Took it to the dealership and they said they found a leaking intake seal. BUT it still sometimes will not idle. Took it back to the dealership, and they cant find anything, (no codes ) . I have run it thru 3 tanks of gas from 3 different gas stations, all to no avail. Anyone have any Ideas.? Thanks
Old Mar 27, 2017 | 01:37 PM
TXCHOP's Avatar
TXCHOP
I would inspect, clean/replace the IAC if it hasnt been addressed yet. Pull the air cleaner and look to see if it cycles properly.
Old Mar 27, 2017 | 02:41 PM
SIDECAR BOB's Avatar
SIDECAR BOB
It could also be your speed sensor, when mine went out bike would run alright but would not idle at a stop light either, usually another clue is your self cancelling turn signals wont work correctly either. Sometimes it just accumulates gunk on the top it and can be wiped off . mine didnt throw a code , but some do
Old Mar 27, 2017 | 06:05 PM
baloot-boy's Avatar
baloot-boy
Other than dying at idle, does it ride fine while on the road? Any other symptoms?
Old Mar 28, 2017 | 06:11 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The prior suggestions would be our intial move as well.
Perhaps the tuner that was used at the point of cam install, can be used to adjust.
Scott
Old Mar 28, 2017 | 08:02 PM
huskers1960
3rd Gear
Txchop, Sidecar Bob, = Thanks for the suggestions. I will look into these.
Old Mar 28, 2017 | 08:03 PM
huskers1960
3rd Gear
baloot boy,,, I see no other symtoms, all else runs fine.
Old Mar 28, 2017 | 08:06 PM
huskers1960
3rd Gear
Thanks everyone. I will look into these. Will report back when I check these out.
Old May 1, 2017 | 10:19 AM
huskers1960
3rd Gear
OK, Finnally got around to checking a couple of things. AIC is working correctly. Cleaned pintle with carb. cleaner. So far Idle problem seems to be fixed. I will clean it one more time, but so far , so good. Thanks everyone for the help. Awesome site.
CGreasamar
Aug 18, 2018 07:16 AM
VTL nut
EVO
Apr 29, 2013 03:12 PM
mitman76
Exhaust System Topics
Sep 9, 2012 09:44 PM
Mario77746
May 13, 2009 12:15 PM
dgriffith
Aug 26, 2007 03:57 PM
