Cam poll: best low to mid torque
I would however disagree that upgrading a stock or Stage 1 motor with a performance cam set will only add 2-3 HP/TQ; have seen more many times.
“Thanks for reaching out to Fuel Moto. I did look at the Forum and I personally do not agree with some of the ideas. Changing head gasket would not be fruitful based on the cost versus outcome. Going to a .030 gasket would raise your compression by a couple of tenths and would, from my perspective, require removing the cylinder to replace base o-ring. If you are doing the work yourself that is not a huge deal but it is if you are not. Any one of these cams would see some gains with a modest increase in compression, but again I do not feel the gain is worth the cost. If you are chasing every possible tenth of torque there are several things to discuss and the largest being exhaust. These are all good cams and lets be honest here the final outcomes will be slightly different at best. No cam in a "stock" motor can offer ten more hp or tq, we are talking about 2-3 differences. I personally like the torque curves we see with the 222 a bit better since it typically is a broader curve than the others.
I hope this is a help and please get back to me with any questions.
Thank you.........Bob”
Crap, missed that 2-3 pick up in power. Maybe he meant a 2-3 gain in hp/tq from the gasket... Without a doubt a cam swap will make more of a difference in hp/tq than 2-3...
Rocker housing bolts torque to 10-14ft-lb. Push rod setting will depend on current preload. If set to .140", readjustment is necessary but if preload is set to .100" no readjustment is necessary. Having said that, I would readjust regardless of current preload because I am an **** retentive SOB.
There are many reasons why one should own the OEM service manual; not just motor work. These are machines and they will break and there are many maintenance items that are clearly instructed in the service manual and will save a DIYer lots of money.
Yeah, I think I'd be too nervous to attempt this without guidance.
The world would not come to an end even if you did **** up and disturb the cylinder base o-ring; several ways to over come the ****up.
1. Pull the cylinder, replace the o-ring, get a ring compressor and drop the cylinder back down on the piston; it would take all of 30 minutes.
2. I will get shade for this one, clean up the o-ring and the cylinder base to case surfaces, apply some Three Bond 1194 (Yamabond will also work) to the cylinder base and case surfaces, place the o-ring in the groove, drop the cylinder and torque to spec. Again, a 30 minute task. I would go so far to say that if the o-ring appeared damaged, I would remove it and rely on the Three Bond to seal the joint.
I have assembled motors that have had cases opened up for larger cylinders where the case o-ring groove has been removed, no base gasket, only Three Bond to seal the cylinder base to case joint and have not had any seepage from that joint. Not to say that at some point, say after 50K or more miles some seepage might occur, don't know but so far 35K miles on my own all bore 107 (124TQ/110HP) and no seepage.
Not suggesting that you take on a project you are not comfortable taking on, just saying that there are more ways than one to "skin a cat".
