Evo crate engine
Old Apr 16, 2017 | 02:39 AM
Oz Nightrain's Avatar
Oz Nightrain
Originally Posted by Adam76
no major problems, just thought I would give it a top end freshen up while I was putting a performance cam in. Thought it would need a good learning project for myself.
My old boss had a stock 1996 evo Fatboy and thing went around the clock and then some with nothing more than regular maintenance. So I'd say a rebuild is probably not needed unless you're doing a big bore or something. Then go for it!
Old Apr 16, 2017 | 03:59 AM
DingusDan's Avatar
DingusDan
40,000km????? You have at least 200,000 good more kilometers left in that engine. Then you might need a set of pistons and a rebore, some valves and guides maybe, a few hundred dollars worth of parts and as much again for machine shop services. The bottom end probably won't need touching for another 200,000km after that.
40,000km is just broke in on an Evo. Put your performance cam in and ride on. Perfect.
Old Apr 16, 2017 | 04:15 AM
grbrown's Avatar
grbrown
Cool
H-D used to offer a factory rebuild service for Evos but seem to have dropped that in recent times. They still do twincams. S&S may still provide a rebuild service, but obviously either H-D or S&S involves shipping an engine in both directions, which I reckon rules them out anyway. Here in the UK we have similar problems to you down under! That's why I bought an S&S engine. They have a solid reputation and also a factory authorised service centre over here.
Having owned Harleys as a Jonny Foreigner for over 40 years I suggest you have to get used to spending! There is no cheap way to do major work on a Harley - either you grin and bear it, or trim your ambitions to the minimum you really really want. At 40k km I very much doubt if your engine needs bottom end work. Having said that, when I had my original Evo stroked, my indy used the same conrod bearings, but honed them and installed larger rollers, as they had gone slightly out of round. Yours may have also done that, however they will still survive for a great many more km yet.
It seems we can set aside replacing your engine, so what would you like of it in the way of improved performance? We are here to help!
Old Apr 16, 2017 | 05:38 AM
Arseclown's Avatar
Arseclown
I'd save the time and money with with the top end freshen up. Just upgrade the cam and enjoy it. Good luck.
Old Apr 16, 2017 | 06:00 AM
smitty901's Avatar
smitty901
1996 EVO is just broken in.
Old Apr 16, 2017 | 06:38 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Hell thats only 24,000 miles.... Just broke in.... As noted, just do the cam and maybe an S&S carb and good pipes..... I wouldn't touch the heads unless you plan on porting and upping the comp a little.....
doesn't Spanners39 live in New Zealand.... He still has a shop. [/B]
I'm sure he could help you......
Old Apr 16, 2017 | 07:20 AM
grbrown's Avatar
grbrown
Wink
Graham, doesn't Spanners live in Australia.... He still has a shop.
I'm sure he could help......
Unfortunately he's in New Zealand, which isn't exactly on the Oz doorstep!
Old Apr 17, 2017 | 11:57 PM
13RoadKing's Avatar
13RoadKing
Engine has to be diagnosed and bad parts replaced. Your old engine possibly need $100 part replacement. Most car engines I repair need $100-200 parts. Do you want to pay for engine more money than value of your bike?
I knew some guy who was sending Harleys to Australia.
Old Apr 18, 2017 | 04:52 AM
Adam76's Avatar
Adam76
thanks mate, much appreciated. Worst case scenario I think I can get S&S replacement cylinder and install them with a new cam all for not much money.
Cheers
Old Apr 18, 2017 | 05:06 AM
grbrown's Avatar
grbrown
Red face
There are higher CR aftermarket pistons available and a decent Harley dealer or indy should be able to hone your current cylinders to match them. Should be cheaper than buying new cylinders. Add a suitable cam and a fresh set of gaskets and you will have a worthwhile boost in performance.
Be aware that boosting performance can get addictive! With my Evo I've gone from a new stock bike through stage 1 mods, stroked and tuned the engine, then installed a 107" S&S - now a 124" sounds quite attractive.....
Joedirt69
EVO
21
Dec 20, 2022 06:22 AM
Amos Iron Wolf
EVO
42
Jul 18, 2017 05:48 AM
russell6hp
Apr 23, 2010 10:43 AM
Rebel78
Exhaust System Topics
Jan 19, 2009 05:44 AM
Ronbo
Apr 20, 2006 09:22 PM
