Big bore break in issues 02 dyna...fueling??
Old Apr 17, 2017 | 07:39 PM
ractrev's Avatar
ractrev
I am with everyone else on the ignition.
On my 10.5:1 95, I was running 200 main, 45 slow for jets and a 5/5 on my DTT. this was with Woods TW8 cams.
Now after a lifter roller went south, I switched to the S&S 585 cams like you. Now I am a bit rich on the main so I will be going to a 190. I also have been playing with the ignition, and find the 585's like even more advance - I am at 6/6 now and it runs nice there. You REALLY want a good ignition. I run a wide band O2 sensor and a gauge in my dash for instant A/F readings - it really makes tuning way easier.
Old Apr 17, 2017 | 08:27 PM
Max Headflow's Avatar
Max Headflow
I'm surprised you are running that much timing.. I usually find more power with less. Have you check CCP?
Old Apr 18, 2017 | 04:56 AM
ractrev's Avatar
ractrev
According to everything I have read, I am surprised as well. I have not checked CCP since the cam change - I have only ran a couple tanks of gas since as well. After the change I was running 5/5 still. It seemed soft on the bottom end, and rich across the board. Just for grins I tried the 6/6 setting - it woke this thing up and helped the A/F readings. I am still rich on the main, but good everywhere else. I really expected some ping or hard starts but nothing yet (these are easy starts so hard start should not happen).
Old Apr 18, 2017 | 07:36 PM
pegskraper's Avatar
pegskraper
Sorry I've been busy... looks like I'm gonna be picking up a daytona twin tec ignition here right away.. Should I spring for the dtt coils too or would the stock ones work well enough?
Old Apr 18, 2017 | 08:06 PM
Max Headflow
Stock coil is is fine.. With the TCs, they went to a 1/2 ohm primary which likely boosted the output to over 30KV.. They work quite well. If anything, close the plug gap to 0.035..
Old Apr 19, 2017 | 07:55 AM
pegskraper's Avatar
pegskraper
Originally Posted by Hillsidecycle.com
Start, with a DDT ignition at Mode, Multi-spark, 2/2, 6000, on that.
OEM ignition can/will blow the top ring land off that.
When you say DDT ignition, do you mean the carbureted TC88 ignition by Daytona Twin Tec? Just verifying, it's close to 500$ cdn when I order it online, I don't want to buy the wrong unit. I spent 4k on this build so far so I don't want any more surprises...thanks
Old Apr 19, 2017 | 08:12 AM
pegskraper's Avatar
pegskraper
Is this the one I should be picking up?
http://www.ebay.ca/itm/Daytona-Twin-...pYqTq7&vxp=mtr
It says it's compatible with the 1999-2003 twin cam 88s..just wanna be sure
Old Apr 19, 2017 | 10:58 AM
ractrev's Avatar
ractrev
That is the one I am using
Old Apr 19, 2017 | 11:10 AM
Max Headflow
Yep.. Gota get the year right... Need the 2 connector version up til 2003. Very good ignition..
Old Apr 19, 2017 | 02:03 PM
LazySundays's Avatar
LazySundays
Double check your part numbers but this guy is great to deal with and he's in Canada.
http://www.heritagecycleworks.com/Pr...15&SubMenu=110
