Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Are you planning to go with chain or gear driving cams? If that .001" is correct, you should be perfect for gear driving, I would think.
I'm running the stock chain setup. I think the modern hydraulic setup is plenty reliable so I wasn't concerned about that. However, at a bike show a few weeks ago S&S had camplates set up with a old style spring tensioner chain, a new style hydraulic tensioner chain, and a gear drive setup. The gear drive required noticeably less force to spin, with the spring style the most difficult to turn. Not sure it would equate to a measurable power difference at the rear wheel, but it was something.
I bet it would make turning the engine over a little easier but in operation i don't think you'd feel the several hundred spent to get there. I'm with you on chain drive being fine
That's interesting. I've been to engineering industry talks about changes in car engine design, to reduce parasitic losses, increase performance, reduce noise and emissions, also improve fuel consumption. It's disappointing to discover that the MoCo has missed that, although I suspect the chains are less noisy than gears.
I've got an AIM VPC, a Barnett spring (not the heavy duty one...can't remember the part #) and Barnett clutch disks already. Hopefully that's enough, but we'll see.
I've got an AIM VPC, a Barnett spring (not the heavy duty one...can't remember the part #) and Barnett clutch disks already. Hopefully that's NOT enough, but we'll see.
Fixed it for you
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
117" was a good choice, if I had checked my crank runout before buying parts - that's what I would have done...
Any clutch upgrades for the extra power?
how do you check the run out at home.
I was thinking i could have the dealer do it but, at that point. The chest is open and the labor is 1/2 done. Why not just in stall the cams/gear if with spec..and chain cams if not... that would require having both types of the chosen grind on hand at thhe time of testing to avoid basically paying for the cam install twice. By having it tested then getting a set of either then going back in for an install.
