107 questions compression.
Old May 1, 2017 | 05:29 PM
brad75raiders's Avatar
brad75raiders
Default 107 questions compression.
IF I have stock heads .30 head gasket and JE 107 10.25:1 Pistons running Andrews 57h in my 2007 Dyna what is my compression. I ask because the 57h is supposed to like 10.1 to 10.2. anyone have an Idea? How much more could one expect tq wise for heads done as well
Old May 1, 2017 | 06:09 PM
misfitJason's Avatar
misfitJason
I don't know exactly because you are missing some info. Here is a link to play with
http://www.bigboyzheadporting.com/TwinCamComp.htm
Old May 1, 2017 | 06:14 PM
brad75raiders
I have put numbers in but don't know we're to add the piston compression
Old May 1, 2017 | 07:35 PM
tonebone_79's Avatar
tonebone_79
Pistons are most likely -1.5cc, but what are the heads cc's and how far in the hole are the pistons?
Old May 1, 2017 | 10:11 PM
brad75raiders
dont know yet need to pull everything apart and find out its 96 now
Old May 2, 2017 | 06:34 AM
prodrag1320's Avatar
prodrag1320
you need to find out the dome cc,and actual chamber cc.HP/TQ increases from getting the heads done will depend on who does the heads.a good porter can set your heads at any compression ratio right at 10.25-1 if that's what your looking for
Old May 2, 2017 | 09:38 AM
djl's Avatar
djl
The OP does need head CCs and deck height but for planning purposes can use 85cc for chamber volume and .005"-.007" for deck height. However, sounds like the JE pistons are domed to generate 10.25 static, probably 6cc. The link you provided to the BB compression calculator should help the OP answer his own questions.
Old May 2, 2017 | 11:17 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
X3.
Scott
traveler
Exhaust System Topics
Mar 25, 2020 10:04 PM
ultraclassic53
Nov 5, 2012 10:25 PM
Sallyman
Mar 21, 2011 08:14 AM
Night Hog
Feb 5, 2010 02:09 PM
softail99custom
EVO
Jan 21, 2010 08:45 AM
