Lifter Advise
Old Jun 4, 2017 | 03:57 PM
TBagger's Avatar
TBagger
Default Tappet Advise
So I've been getting some lifter fluttering/itchy noise. Can't hear it at cold start but you hear it around 2-3k RPM under driving load until warmed up. Even then it's still present but diminished. Can not hear at higher RPM's. Also you can notice more in hotter temps. I've switched oils to a Red Line 20W-60 and that helped but still there. I'm running the SE 110 kit, with perfect fit pushrods, the SE tappets and 585 cams. So I'm wondering if could put the stock tappets back in and rid my self of the noise. Or could I get a replacement tappet set that will work with these perfect fit rods. I'd really rather not run adjustables rods if I can.
Looking for some advise and input.
Thanks !
Old Jun 4, 2017 | 04:08 PM
rdc401's Avatar
rdc401
S&S lifters
Old Jun 4, 2017 | 04:12 PM
djl's Avatar
djl
If the valve train noise presents at a certain rpm range, say for talking purposes, 2600-2900, Rocker Lockers may solve the problem of the rocker shaft rotating in the support and generating the tick. You might take the time to pull a rocker cover and support and take a look at the shaft for witness marks. Check out Rockerlockers.com; I would post the link but copy/paste is not cooperating.
If that is not the problem, there are many better choices than SE lifters starting with CompCams VThunder 850-1s at about $70 all the way up to S&S Premiums, Woods Directional etc in the $250-$300 range; all will work with the PF pushrods.
You might also do the math on your valve train stack up height to be sure the PF pushrods are providing sufficient preload to reduce the valve train noise. At the end of the day, adjustable pushrods may be the solution. Not sure what you have against them when so many use them with no issues.
Old Jun 4, 2017 | 04:49 PM
TBagger's Avatar
TBagger
I failed to mention I did do the rocker lockers as well. As for the adjustables not aganst them just concerned about getting preload and adjustment correct.
Old Jun 4, 2017 | 05:16 PM
cvaria's Avatar
cvaria
dont sweat it. you can do it. s&s lifters all day long
Old Jun 10, 2017 | 03:48 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Adjustable pushrods loading the lifter to .140".
Scott
Old Jun 10, 2017 | 08:43 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Scott
Perfect fit pushrods will not get you there.......
Old Jun 11, 2017 | 05:03 AM
TBagger's Avatar
TBagger
Thanks guys ! Going with SE Adjustable set with 3.5 turns for the preload. If the fluttering is still there, I'll get into the lifters then.
Old Jun 11, 2017 | 06:29 AM
98hotrodfatboy
If the SE adjustables are 32 tpi then you will need to set the preload to 27 flats or 4 1/2 turns..
Old Jun 11, 2017 | 07:45 AM
ntraindavefl's Avatar
ntraindavefl
I thought the SE ones were only 24 tpi. Is there a 32?
