Carburated 88CI sputtering
Old Jun 11, 2017 | 08:42 PM
JerryCanada's Avatar
JerryCanada
Default Carburated 88CI sputtering
Hey guys,
I own a 2004 Fatboy with the 88ci carb with about 26k km (16k miles). Went on a day trip yesterday and when I first started it notice idle was off and it sputtered intermittently. Never stalled and was cold so didn't make much of it and left. On the highway it drove normally. Later in the day got to a few intersections and it start doing that sputtering again when putting load on engine. Coming back on highway when going up some steep hills it would miss a heartbeat every now and then.
I will put new plugs in tomorrow even though they both looked fine just for piece of mind but would anyone have an idea as of what could be the cause of this?
Thanks,
JerryCanada
Old Jun 12, 2017 | 04:31 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd start by insuring the air/idle misture screw is out 2 1/2-3 turns, and bet that either the use of a 48, or 50 pilot jet is what you'd want.
Shy of that, insure you have proper petcock fuel delivery.
Scott
Old Jun 12, 2017 | 06:37 AM
JerryCanada
Thanks for the reply Scott. I've owned the bike for 3 years and it just started to do this. Would the mixture setting be something that would need attention every now and then?
Old Jun 12, 2017 | 07:09 AM
Hillsidecycle.com
Sponsor
Not unless the engine is starting to show signs of becoming weak, or your current brand of fuel has changed dramatically.
Perhaps an inspection of the vacuum piston assembly, as well, would be in order.
Scott
Old Jun 13, 2017 | 01:26 PM
SafetyFifth's Avatar
SafetyFifth
X2 on checking that CV diaphragm for tears. I'd also check your intake seals.
Old Jun 15, 2017 | 08:03 AM
Hillsidecycle.com
Sponsor
Yep.
Scott
Old Jun 17, 2017 | 08:56 AM
JerryCanada
After changing plugs and switching gas I took it out and it ended up only running on the front cylinder. No fire at the back one. Took seat off and noticed the plug for the module on rear fender has somehow managed to come loose so pushed it all the way in and has been working like new since. Thanks for all the replies!
Vmann
EVO
17
May 29, 2017 06:00 PM
BigMESA
Sep 10, 2014 05:38 PM
lennyb3us
May 27, 2012 07:29 PM
Krazyshark
Ironhead
25
Jan 12, 2012 09:21 PM
brooksweith
Jun 3, 2007 11:49 PM
