Pump it
Old Jul 12, 2017 | 08:16 PM
Darrell Sowards's Avatar
Darrell Sowards
Stage II
Default Pump it
looking to go to a 107 bb kit. Have a 2013 103 with air cleaner ug and python 2 into 1 with pcv and autotune. Would like to keep the tuners but wanna get the most out of the kit. Suggestions
Old Jul 12, 2017 | 11:11 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
This isn't Twitter, so you are allowed to give us more information about what's on your bike at the present time and what level you really want to get it to!
Old Jul 13, 2017 | 04:54 AM
grbrown's Avatar
grbrown
Wink
I'm not sure there is any reason to change anything - just get your bike dyno tuned afterwards by a competent shop, to get the best out of it.
Old Jul 13, 2017 | 07:18 AM
ntraindavefl's Avatar
ntraindavefl
What's an ug?
Old Jul 13, 2017 | 07:35 AM
cdonis's Avatar
cdonis
Budget, riding style , expectations needed.
Old Jul 13, 2017 | 08:52 AM
Darrell Sowards
Stage II
Sorry guys. its a 2013 Road Glide
air cleaner upgrade
python 2 into 1 side dump exhaust
255 cams
power commander V tuner
Power commander Autotuner
25,000 miles and the front cylinder is cracked
I have about $4500 to upgrade. Since I need to replace the front jug I want to pump it to a 107. I am seeing with the right setup it can see up to 125 hp and about 123 torque.
I would like to port and polish the heads and probably size up on the throttle body. I would like to keep the tuners i already have.
I am a daily rider and have put as much as 18000 miles on a bike in a year. I would like to have some fun power but want to it to be a reliable daily scoot.
Old Jul 13, 2017 | 08:59 AM
grbrown's Avatar
grbrown
Wink
Darrell, I suggest you follow the example set by Dave of post #4 and talk to Scott at Hillside. He can provide those numbers from a 107" and all the hardware you will need! I suspect your Python will have to go, but he can advise.
Old Jul 13, 2017 | 09:15 AM
Tedwilliams09's Avatar
Tedwilliams09
I second that. Pretty much the numbers I got out of my 107 kit that Scott did.
Obviously different pipes. But he will take care of you
Old Jul 13, 2017 | 09:21 AM
ntraindavefl
Good advice, Scott and his team at Hillside produced a 107 for me with 124tq 121hp and target64's 107 with 124tq 129hp just to name a few of many like this. Your pipe like grbrown states may be an issue for numbers if the lengths of various areas of the pipe are too short. Scott will advise and your budget should be no problem.
Elvis Nixon
Dec 15, 2015 12:34 PM
Matt Howell
Jul 13, 2014 06:32 PM
mobeasto123
Jun 24, 2010 11:56 AM
Warrior Redleg
Mar 15, 2010 11:15 AM
jasnusc
Oct 4, 2009 01:42 AM
