A new racket
Old Aug 28, 2017 | 12:04 PM
2009blackpearle's Avatar
2009blackpearle
Default car lifter
no sure the car lifter is the best thing to put in a bike, dimensions may be very similar, not sure port sizes externally and internally match . I put s&s in mine 130 bucks for 4 I had Harley b lifters to start with did cams and was pretty noisey. then a roller started to pit, then u could only buy c lifter from Harley piece sh t didn't pump up too well bleed down fast and tick like u wouldn't believe . tried both at .130 or 3 full turns. the s&s is the quietest lifter Iv ever heard. here is a s&s video on using car lifters in a bike not sure if its totally true but here it is. for 130 best lifter ive had out of 3 diff sets. inlet hole on the c series is about half the size of the s&s lifter not sure what internal diff is . oil pressure in car motor is probably 40-50 psi Harley if pump and wearing parts in good shape is about 32 at idle probably 12-15psi.. manual for pressure test on hot motor says about 30 psi at 2000 rpm.
Old Aug 28, 2017 | 04:15 PM
Screamin beagle's Avatar
Screamin beagle
https://www.youtube.com/watch?v=fMoRaHJRrhc
I have a brand new set of s and s in there...I just brought two of cheap chevy ones to swap out with them to make sure it wasn't a bad lifter...so I just rotated them from front to back and then took them back out, i had no intention of leaving them in there.I've seen that video too...not sure if they're just trying to sell parts or not but 130 bucks is cheap insurance to make sure my motor doesn't meltdown lol. Just got home from work and pulled the front rocker cover off and ran the bike...good news is there's plenty of oil making it up top on the front cylinder ...bad news is still don't have an answer, time to pull the rear I guess? I know these motors make noise,especially the 110 but this is a new noise so that's got me freaking out.Maybe this bike just doesn't like redline, started this soon after I switched from mobil 1...I might dump it and try some Dino oil. Or maybe I'll follow the wife's advice and "shut up and ride it and if it breaks then you'll know what's wrong" just hope she remembers that when it comes time to finance the motor rebuild.
Tommy Hager
EVO
64
Jun 28, 2022 12:04 PM
Polodinks
Shovelhead
58
Aug 15, 2019 06:14 PM
buford
Nov 3, 2015 06:08 AM
mjunk1
EVO
Jul 5, 2011 03:54 PM
beachspur
Feb 27, 2010 06:58 AM
