General Question on Heads.
Old Aug 24, 2017 | 12:09 PM
Garrman's Avatar
Garrman
Default General Question on Heads.
Hi Guys,
I am planning to do some work on my 2002 FLHPI in the near future. Part of that work would be addressing the cylinder heads. A friend has some SE heads he wants to sell me but I keep reading that 06 heads are a better way to go. At this point, I am inclined to find some 06 heads and have them re-worked.
Here is where I am getting confused. There seem to be a multitude of part numbers that appear to be 06 heads. I have seen 17192-06/17193-06 and 17192-06/17193-06 for example.
Any suggestions as to part numbers for blacked out 06 heads for a TC A motor?
I am sure I will have more questions later but this would be a great start.
Thanks,
Garrman
Old Aug 24, 2017 | 01:31 PM
djl's Avatar
djl
If the heads are going to be worked, the castings don't matter. Buying a set of '06 up heads is a waste of money; just have yours worked. Many porters will work with customers on an exchange basis and will send a ported set and charge the customer with a "core" charge which will be refunded when the porter receives the customers heads in good condition.
Old Aug 24, 2017 | 03:29 PM
Garrman's Avatar
Garrman
djl,
Sound advice on just re-working the stock heads. As I understand it, the biggest difference between the early TC heads and the 06 and later was exhaust port size and single wound valve springs?
I would assume a competent shop would know all this but I would like to go into this with eyes wide open.
Garrman
Old Aug 24, 2017 | 03:42 PM
wfolarry's Avatar
wfolarry
Those early SE heads work really well on a 95 with a little work.
Old Aug 25, 2017 | 08:46 AM
djl's Avatar
djl
Originally Posted by Garrman
djl,
Sound advice on just re-working the stock heads. As I understand it, the biggest difference between the early TC heads and the 06 and later was exhaust port size and single wound valve springs? I would assume a competent shop would know all this but I would like to go into this with eyes wide open.
Garrman
Beehive springs, 5/16" vs 7mm valve stems and exhaust port configuration are the main differences between early and late. Best bet would be to talk to a couple of head porters (two have posted a reply) and they will "open your eyes".
EDIT: correct 5mm to 5/16.
Old Aug 25, 2017 | 09:09 AM
prodrag1320's Avatar
prodrag1320
For mild headwork,the later heads are a better choice,but of a full port job is going to be done,castings really don't matter
Old Aug 25, 2017 | 10:10 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by djl
Beehive springs, 5mm vs 7mm valve stems and exhaust port configuration are the main differences between early and late. Best bet would be to talk to a couple of head porters (two have posted a reply) and they will "open your eyes".
I think you mean 5/16" versus 7mm valve stems.
Old Aug 25, 2017 | 01:44 PM
djl's Avatar
djl
Yes, I do. Thanks for the correction but there is a reason for the error and I will explain.
When I was in the Army ('70-'72), I was originally assigned to a rifle company in the 25th infantry division. The company clerk/typist was a short timer and I got snagged as a temporary replacement until a new clerk/typist could be found. I assume I got snagged because I had a college education which meant I knew grammar and how to spell. I had taken typing my junior and senior year in high school (with all the cute girls) and the First Sargent soon learned that I could type pretty fast, spell and made few mistakes. So, First Sargent advised the CO and I was soon transferred from the rifle company into the S3 section of the HQ company where I typed my *** off. So, while I took **** from the guys in high school for taking typing, I dated more girls than they did and knowing how to type got me out of a rifle company.
But I digress. So sometimes, I type faster than I think; actually most of the time I type faster than I think.
Old Aug 25, 2017 | 02:31 PM
Max Headflow
That's funny.. I type way slower than I think so sometimes I forget where I'm going..
Old Aug 26, 2017 | 08:41 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Been there done that... Oh boy.....
huntingnut
Sep 11, 2014 02:38 PM
ThaGlyde
Feb 20, 2012 06:31 PM
Hawghauler
Exhaust System Topics
Sep 23, 2011 03:47 PM
BONERACIN
May 9, 2008 03:52 PM
turn55
Jan 26, 2006 01:29 PM
