Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
It won't.. The HD heavy spring is only 380 lbs. You might get away with an AIM or Barnett 480 lb spring and +1 clutch pack.. You are better off going for a scorpion or bandit clutch if you want to control lever pressure.
The 6 lightest springs in the kit won't hold. It comes with 3 sets of springs, it's adjustable as max says
Ok looks like I will have to put a Bandit clutch on my list. Always wanted one anyway, now I have a reason to get one. Hopefully the AIM VP95IV holds up in the meantime.
136 ain't 140 square, on a legit DJ Dyno, so put that to bed. Not happenin'.
As far as the clutch, contact Barnett for their low profile lock up that fits under your derby cover. Will easily hold 130.
Gee thanks. Well I hope that this 124" makes a little more power than my 103", but probably not.
