1992 fxr base gasket leak
Old Sep 20, 2017 | 10:14 AM
1992fxrmark's Avatar
1992fxrmark
Stage III
Default 1992 fxr base gasket leak
Hey everyone. I'm doing base gaskets on my 1992 fxrs with 7000 original miles. When I tear it all apart while I'm in the motor should I replace the piston rings and head studs? And anything I should look out for ? Thanks
Old Sep 20, 2017 | 12:07 PM
northeastconfederate's Avatar
With 7000 miles on a 25 year old bike, theoretically tje rings should be fine. However, it's pretty likely the cylinder walls have gotten a little rusty numerous times and the rings scraped that off - or maybe they got a lot rusty. I would at least do a compression test and a leakdown test before disassembly. This will tell you a lot. If you have a borescope or can borrow or rent one, take a look inside. That may be a waste of time, since you'll see when it's apart, but a borescope would give you a clue what you're in for.
I'd replace valve seals for sure, it's almost a sure thing they're dried out and hard and pretty much good for nothing.
Old Sep 20, 2017 | 08:45 PM
feguy1's Avatar
feguy1
Rings are cheap, Do it. Hit it with a glaze breaker, the pistons should be fine. Cylinder studs should be good, I have never replaced any unless they were pulled out of the case. I always used copper coat on the base gaskets, even though Harley says not to. Never had another leak again.
Old Sep 20, 2017 | 09:28 PM
marcodarq's Avatar
marcodarq
take a good look at the areas around the tappet blocks,,,,that year engine had issues with oil leaks that looked like a base gasket leak, but were actually the tappet block gaskets,,,make sure that you clean it up really well and be sure it's the base,,,,,might save yourself some time and money,,,,if you already know for sure it's the bases the advise already given is pretty sound.
m
Old Sep 21, 2017 | 05:03 AM
1992fxrmark
Stage III
Have you guys done it with the motor in the frame? If so how would I get the pistons top dead center with the primary still on?
Old Sep 21, 2017 | 05:22 AM
feguy1's Avatar
feguy1
Only way I have ever done it is with the motor in the frame. Jack the rear wheel up, place the trans in 5th, use the rear wheel to turn the engine as needed. I never pull an engine unless the cases have to come apart for some reason, or I am just swapping the entire engine assembly. BTW, when you get the jugs off, cover those spigot holes! Nothing worse than dropping something into the lower end!
Old Sep 21, 2017 | 05:52 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Might want to true those cylinder bases, as they were not machined from HD.
Cast, not machined.
The bores should be checked with a bore guage, if OK, hone/re-ring.
Scott
Old Sep 21, 2017 | 06:30 AM
1992fxrmark
Stage III
You guys think downloading the service Manuel online would be good? Or should I try to find a hard copy for it.
Old Sep 21, 2017 | 08:08 AM
feguy1's Avatar
feguy1
I have always preferred paper books. That's just me.
Old Sep 21, 2017 | 02:54 PM
marcodarq's Avatar
marcodarq
the online copy will suffice, but I like paper i can carry out to the bike with me. yes you can do the job with the engine in the frame and no primary removal. take the tank off and you will have room. with an fxr you might have to loosen or remove engine mounts and raise or lower the engine some and cut up some allen wrenches to get the rear rocker box apart, but it can be done. Scott gave real good advise on the cylinder prep and can do that work for you if you ship your stuff off to him once you get it apart. HD's are not rocket science, get the book, take your time, ask questions when you get stuck and you can get it done.
m
01fxdxt
EVO
15
Dec 4, 2013 04:13 AM
JefferiesHD1
Exhaust System Topics
Mar 16, 2013 11:11 AM
dirtbag1
EVO
Oct 25, 2012 06:03 PM
BiggestDawg
Feb 25, 2008 04:41 PM
danstehler
Flathead
Aug 24, 2007 03:42 PM
