Atf in primary
Old Oct 9, 2017 | 03:13 PM
Cousy's Avatar
Cousy
I've got Ford ATF in my Springer primary right now. Works just fine. Can't tell any difference from the Redline primary fluid. It's cheaper than HD Formula+. That's about the only advantage I can think of.
Old Oct 12, 2017 | 04:00 PM
QNman's Avatar
QNman
I use half Mobil 1 ATF, one quarter WD40, three ounces of K-Y and a shot of Kentucky bourbon. Bulleit works best, but Jim Beam will do in a pinch.
Old Oct 13, 2017 | 06:07 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
That is quite a "custom blend"........lol.....that bike will need a designated driver.......
Scott
Old Oct 13, 2017 | 09:16 AM
cvaria's Avatar
cvaria
I was using trick shift atf. I stop because of the noise (clank) and funky shifts. Just tried moble1 75w-90 gear oil and will be trying red line vtwim primary next. Hopefully i arrive at something hreat. Swapping out fluids evey 200 miles is wasteful.
Old Oct 13, 2017 | 12:22 PM
bagga's Avatar
bagga
i have used, the HD primary oil, 10w30 motor oil, 10w40 motor oil, 20w50 harley motor oil and atf type f in the primary of my 85 flhtc. i couldn't tell the between any of them. i have 20w50 in it now because that's what i had on the shelf when i was changing it. the old 85 still has the original clutch and primary chain in it with no signs of wear, about 100k on it.
Old Oct 13, 2017 | 12:57 PM
lt1-xjs's Avatar
lt1-xjs
Mobil 1 Racing 4T 10W40 works very well.
CT-Bagger
Oct 15, 2013 07:46 AM
albngore
Jan 15, 2012 07:48 PM
Bluegrasser
Oil Archive (no new posts)
Apr 16, 2010 12:17 PM
edgerider
13
Jul 28, 2007 11:36 PM
02deucerg
Nov 4, 2006 01:37 AM
