Full synthetic or not in primary ?????
Old Oct 13, 2013 | 10:03 PM
CT-Bagger's Avatar
CT-Bagger
Default Full synthetic or not in primary ?????
Why shouldn't I run 20W-50 Amsoil in my primary???
The MoCo suggests there own non-sythetic lube for the primary which differs from engine oil.
Your feedback please.
Old Oct 13, 2013 | 10:16 PM
Sprinter7x's Avatar
Sprinter7x
I tried synthetic in the primary,didn't like it,same with a friend at work,the clutch felt like crap,was slower to grab but when it did it was like all or nothing.-The H-D stuff is good,if you don't want it try some Castrol gtx 20-50,it will work fine.
Old Oct 13, 2013 | 10:20 PM
ColoFXDC's Avatar
ColoFXDC
Use a mixture of boggle timer sand and tooth paste with a 100:1 mixture of water.
Old Oct 13, 2013 | 10:36 PM
Hulkss's Avatar
Hulkss
Amsoil 20-50 works great in engine, transmission, and primary chain case. Been using it for years.
Old Oct 13, 2013 | 10:48 PM
skratch's Avatar
skratch
its not necessarily synthetic that you want to avoid, its anything with any friction modifiers in it. they will cause the clutch to slip.
i use shell rotella t in my primary. get it in the gallon jug at advance auto for around $12. that gallon will last you at least 4 primary changes, with some left over. it's jaso rated for wet clutches.
Old Oct 13, 2013 | 10:59 PM
CT-Bagger's Avatar
CT-Bagger
Amsoil recommends 20W-50 synth.
Old Oct 13, 2013 | 11:03 PM
jakenok's Avatar
jakenok
Rotella.
Old Oct 13, 2013 | 11:05 PM
hanny's Avatar
hanny
amsoil or Harley syn either one is fine. gonna get a bunch of opinions about this tho.
Old Oct 13, 2013 | 11:24 PM
2-Piece's Avatar
2-Piece
I've got Rotella T6 full synthetic in mine. No issues and clutch feels fine. I may switch back to Formula + though. I think it might be better for the SE compensator I recently installed.
Old Oct 13, 2013 | 11:29 PM
tubeman426's Avatar
tubeman426
I run 20-50w amsoil works great, checked my compensator and still looks new. I run it in all three holes, it keeps things simple
