Engine RPM rising quickly
Old Oct 18, 2017 | 12:42 AM
Mech883's Avatar
Mech883
Default Engine RPM rising quickly
weird issue today, 1999 sportster 883. Had to shift much sooner than normal today, was in 3rd gear by the time i was at 20 mph. normally that number is closer to 30-35. couldn't get above 50 mph in 5th without the engine sounding like its gonna blow. Any thoughts? Thanks
Old Oct 18, 2017 | 03:29 AM
joe40x's Avatar
joe40x
Clutch slipping
Old Oct 18, 2017 | 10:10 AM
dfwhockey17's Avatar
dfwhockey17
You need a new clutch!
Old Oct 19, 2017 | 01:15 AM
Mech883's Avatar
Mech883
already has a new clutch, clutch issue has been ruled out
Old Oct 21, 2017 | 11:42 AM
dfwhockey17
Then the clutch is not set up correctly. Assuming your belt is not skipping teeth and your final drive is in proper working order, your clutch can be the only culprit...
Old Oct 21, 2017 | 06:51 PM
marcodarq's Avatar
marcodarq
maybe speed sensor or speed issue? did you confirm your speeds somehow?
m
Old Oct 21, 2017 | 07:20 PM
bustert's Avatar
bustert
++++1 mr. m
if there is trash on the speed sensor it will throw off the tooth count, aka, slower indicated speed. sensor or speedo issues.
chestnut
Apr 2, 2018 04:07 PM
crockpot1
General Topics/Tech Tips
Apr 24, 2017 02:19 PM
hd54kh
Nov 11, 2010 09:29 AM
fiveola
Shovelhead
May 18, 2008 01:48 PM
kerberos
Jul 30, 2007 03:12 AM
