Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hello,
Im reinstallin some &S adjustable pushrods into my '01 Fatboy. It has geared cams with a 5700 grind. I had a oil line blockage that had to be cleared nd upon reassembly the gremlins got me and I mixed up my 2 front pushrods identitties. One is about 1/4 inch longer than the other. (Not quickies). Please, which one is exhaust and which is compression. Being asjustaable, I would thik that would be insignificat.
Thank you in advance,
Ron
