Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
A. What’s your power goals? B. What’s your budget?
I recommend a set up from Hammer Performance, anything from mild to wild. They now offer a 1275cc set up!
We side-step that and go to a 1450cc/88" with Axtell 3 13/16" cylinders, when a client wants the big power, w/o increasing the stroke. (but a 106", 4 5/8" stroke/108", 4 3/4" stroke, and if one wants the full enchilada...114" with a 5" arm.....total bad-*** street XL.)
Not only will that run the hp up higher, at 88", but the torque comes way up.
Very common to see 100 ft/lbs from an 88" XL set up.
Scott
Scott
On a 2008 case? That’ll be cheap! Hahahaha
Good luck with the 106” and 114” for staying together! Haha
I guess my impression was it’s a 2008 rubbermount street bike. Have fun funding anything more than a 90” on a a rubbermount. You should quote him haha
A. Whats your power goals? B. Whats your budget?
Originally Posted by Madnss
On a 2008 case? Thatll be cheap! Hahahaha
Good luck with the 106 and 114 for staying together! Haha
I guess my impression was its a 2008 rubbermount street bike. Have fun funding anything more than a 90 on a a rubbermount. You should quote him haha
Dont forget to cut your frame!!!! Haha
Here is some good information. Check it out when you have some free time.
You need to stop drinking and come out of your hole... There's more one company that can build an XL......
Haha , there sure is! I never stated there was only one. Lots of companies, guys and parts. I merely stated my opinion!
Sorry, but blurting about a 106 and 114 inch in a 2008 rubbermount is pathetic. He even stated hed rather pass on an 88 or 90 because he wants to do most of the work.
Desperation is a stinky cologne
How it the work any different going from 88 to 106? As far as I know its simply a crank replace and buy different pistons/cylinders to get deck height correct.. I guess you might need to mod the frame but motor wise?
