Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Have purchased a Rinehart true dual system, SE elite billet cleaner and a Power Vision.was thinking at same time to do cams. Would the TTS-100 cams be a good choice?
thanks
compression,cams & headwork is the way to go.figure what your looking for,what fits your riding style & design a build to suit it.the TTS100 would be a nice,low end TQ cam if that's what your looking for
Bike is a 2014 Street Glide Special. Looking for low end torque and reliable highway cruising.
Cyclerama 570-2
Give Sheffer Performance a call He does a lot Cyclerama Cams .. He's in Evansville In , One of the best around!! You can also find him on Facebook. or Call @ 812-401-8863
Have purchased a Rinehart true dual system, SE elite billet cleaner and a Power Vision.was thinking at same time to do cams. Would the TTS-100 cams be a good choice?thanks
Short answer is yes; a great choice. However, Steve Cole also offers the TTS-150. The 100 is advertised to deliver power off idle to 4000rpm while the 150 is advertised to deliver power from 2200-5200, so you have that option as well. Check out the TTS website, dyno charges and give Steve a call if you have any questions.
^^This^^ For a bolt in cam, this one (along with it's predecessor, the 570) consistently shows the best torque curves I've seen, and I've looked at a lot of them. Make sure you get a good dyno tune to make it really shine, though.
